power seat
Old Apr 22, 2012 | 11:53 AM
baldy's Avatar
baldy
5th Gear
Default power seat
How do I remove the driver seat to replace the power seat rack. seat will not adjust front to back. sounds like broken gear spinning.
Old Apr 22, 2012 | 11:57 AM
94z07fx3's Avatar
94z07fx3
Press down in the front center of the seat. Reach under and unclip the coat-hangar-like wire holding the bottom cushion on and lift out the cushion. Remove the four bolts holding the seat to the rails. Remove the seat. Now you should be able to pull the track in the same direction that you're trying to move it with the switch to expose the four nuts holding the track to the floor. Remove those nuts and lift off the track.
Old Apr 22, 2012 | 12:41 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
It's your seat transmission. You don't have to replace the whole track. Rebuilt seat transmisions are available from CF vendors.
Old Apr 23, 2012 | 04:01 PM
baldy's Avatar
baldy
5th Gear
Thanks for the heads up ! Heading into the the garage to check this out...
Old Apr 23, 2012 | 04:11 PM
baldy's Avatar
baldy
5th Gear
Thanks, I live near the Michigan line. Corvette Central is in Sawyer, Good parts supplier and good prices.
Old Apr 23, 2012 | 04:13 PM
baldy's Avatar
baldy
5th Gear
This may not be such a bad repair after all. I have Corvette Central about 45 minutes from my house. Decent prices also.
To power seat
