clutch screech
Old May 20, 2002 | 02:29 PM
kwd1's Avatar
kwd1
Default clutch screech
Hi all,
I'm a c4 newbie and am wondering if what I'm hearing
is normal or not.
I sometimes notice a sceech type of sound when shifting.
Happens if engine has too many rpms when letting clutch out.
Another way to reproduce is to accelerate in 1st at ~50% throttle
and then press in clutch without immiediately letting off gas.
After a few days of driving I got to where I can shift without
this noise (ie get the rpms right). I'm just wondering if this is normal.
I just got out of a mustang, which had a considerably more forgiving clutch.
tia
Ken
ps car is a 96 lt4; bone stock
Old May 20, 2002 | 02:38 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: clutch screech (kwd1)
I have a similar deal when shifting from 1-2 or 2-3 sometimes. It was mostly when i first started to drive the car and wasn't used to it. I rarely have any noise now.
Its lower than a screech though.. :confused:
Old May 20, 2002 | 02:56 PM
RatRacer's Avatar
RatRacer
Sounds like a pilot bushing going south.
Old May 20, 2002 | 04:04 PM
kwd1's Avatar
kwd1
I remember also another lt4 I test drove did the
same thing.....
Old May 20, 2002 | 04:14 PM
devilfish's Avatar
devilfish
welcome to the world of the loud ZF tranny :) :cheers:
Old May 20, 2002 | 05:19 PM
RatRacer's Avatar
RatRacer
Default Re: clutch screech (devilfish)
Here's a tip regarding clutch noises:
If it squeels when you push the clutch in or begin letting it out, it's the pilot bushing.
If it makes a grinding noise that goes away when you push the clutch in, it's the throw out bearing.
[Modified by RatRacer, 3:20 PM 5/20/2002]
Old May 20, 2002 | 06:00 PM
vvv90's Avatar
vvv90
A Ford to Bowtie convert! Welcome, What part of Chicago are you from?
Old May 20, 2002 | 06:50 PM
kwd1's Avatar
kwd1
Default Re: clutch screech (vvv90)
north aurora actually. Orchard Estates, nw of
orchard and randall, greetings
Old May 21, 2002 | 10:55 AM
kwd1's Avatar
kwd1
Default Re: clutch screech (RatRacer)
Ratracer,
I don't think its the pilot as you describe. It's not every
time the clutch goes in or out, only when the rpms are too
different from what they will/would be with the clutch fully
engaged.
It sounds to me like its the flywheel spinning on the clutch disk
briefly.
thanks
Ken
Old May 21, 2002 | 11:18 AM
RatRacer's Avatar
RatRacer
That's when the pilot bushing does it's job. It is the bearing that couples the engine rpm and the tranny rpm. When the pilot bushing starts to give out it will squeel occasionally when there is a large differential between the rpm of the engine and tranny. When it gets real bad it will squeel any time the clutch is pushed in.
Fortunately the pilot bushing is only loaded during shifts or when you are idling in gear. It is not very critical and you can postpone replacing for a while until it starts squeeling everytime you use the clutch.
I garranty you that it is the pilot bushing.
Old May 21, 2002 | 12:12 PM
kwd1's Avatar
kwd1
Alright dude, thanks for the info. I got the
vette from dealer and it came with a 2 month warrenty,
so I'll have this looked at. Many thanks
Old May 21, 2002 | 12:28 PM
vvv90's Avatar
vvv90
Holy Sheeeeet what a small world, I live in North Aurora too! (as you probably saw from my profile) Orchard Crossing subdivision right across the street :lol: :lol: :lol:
Cool! now I have someone to cruise with :cheers:
To clutch screech
