Turn signal SLOW
Old Apr 24, 2012 | 10:27 PM
rhowdershell69's Avatar
rhowdershell69
Default Turn signal SLOW
Is there anything wrong with my turn signal? It blinks at the pace of a blade of grass growing. When I hit the brakes it no longer blinks. Is this by design for a 1992 C4 Convertible, pictures in my garage, let me know. Thanks!
Old Apr 25, 2012 | 04:17 AM
toptechx6's Avatar
toptechx6
If both sides flash slow it sounds like you have the wrong flasher installed for the turn signals. If it is just one side make sure the bulbs are correct.
Old Apr 25, 2012 | 04:50 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The slowness is because the spring in the flasher is not heating up fast enough.
Old Apr 25, 2012 | 12:32 PM
85 500 horse's Avatar
85 500 horse
This may be a "way out there" reason, but your battery or alternator could be bad. A weak battery could cause your flashers to flicker slower due to an incomplete or weak load. Turn on your headlights and check to see if they are dimmer than normal. If they are, you've probably got a bad battery or alternator.
Old Apr 25, 2012 | 02:03 PM
pcolt94's Avatar
pcolt94
This is a good starting point and what I was thinking also. Don’t have to take anything apart. Check the battery voltage with a DVM while idling and at a higher RPM. Turn on headlights and then check battery voltage. If you are down at 11 or 12 volts, you have a problem.
If voltage is OK then getting to the flasher is a bit more work and I would probably change it next providing all bulbs are good and the correct ones are in there.
Old Apr 26, 2012 | 12:25 AM
Joescrvette's Avatar
Joescrvette
Old Apr 26, 2012 | 08:53 AM
Mikepro76's Avatar
Mikepro76
I have a similar question. My left turn signal flashes quickly and my right turn signal stopped working. I was told to check the bulbs but they all appear to be working. Any thoughts?
Old Apr 27, 2012 | 01:20 AM
Cliff Harris's Avatar
Cliff Harris
A fast flashing rate is the classic symptom of a bulb with a shorted filament. The coils short together and reduce the resistance so the lamp draws more current and causes the flasher to flash faster. The way to find the bad lamp is to remove one at a time and see how that affects the flash rate.
I have heard that you can get "heavy duty" flashers that don't depend on the bulb resistance to determine the flash rate. They are made for vehicles towing trailers which may have a bunch more bulbs than a normal car/truck.
Old Apr 27, 2012 | 08:21 PM
rhowdershell69
Here is my fix..I went the most inexpensive way first. I replaced all the tail lights with standard replacement bulbs, along with a new heavy duty flasher. I found the flashed under the driver panel above my left knee. The job took me an hour and cost less than 25 dollars. I plan on doing led's in the future.
To Turn signal SLOW
