SS brake lines?
Old Apr 25, 2012 | 03:12 AM
ffvetteman's Avatar
ffvetteman
Default SS brake lines?
I am getting some brakes for my 84 for track use and decided to get new lines since mine I think are original. I was looking at Stainless steel lines. Any brands I should look for or avoid? The car is primary a daily driver but I also do some Autocross and track days with it.
Old Apr 25, 2012 | 05:33 AM
ffvetteman's Avatar
ffvetteman
I was looking at the Goodridge G-Stop lines? Any input?
Old Apr 25, 2012 | 07:26 AM
Churchkey's Avatar
Churchkey
Always use Goodridge on the bikes without issue.
Happened to run across a set of Russell that are DOT approved for the Vette. Goodridge may also be DOT, did not look/check.
Old Apr 25, 2012 | 07:44 AM
ffvetteman's Avatar
ffvetteman
Yea I think they are. I will double check.
Old Apr 25, 2012 | 08:11 AM
Aardwolf's Avatar
Aardwolf
I got mine from DRM, and the brake bias spring too. Good stuff!
Be out at Road America at all?
Old Apr 25, 2012 | 09:01 AM
c4cruiser's Avatar
c4cruiser
I bought a set of Russel lines for my old '92 some years ago. The rear lines were so short, there was no slack in them once a rear wheel was off the ground. They never did break, but because of that I would never buy a set again.
I have a set of Earl's on my '87 autocross/track car now and never had a leak or any other issue. Goodridge is another good brand.
Old Apr 25, 2012 | 09:25 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I bought a set of Russel lines. Like c4cruiser said, they work but they are awfully short.
I ended up not using them and bought the lines from DRM. They fit awesome. I would highly recommend them.
Old Apr 25, 2012 | 09:33 AM
ffvetteman's Avatar
ffvetteman
Thanks for the info. I'm looking at the Goodridge. Good price for all 4. I will have to check into the DRM also. I am hoping to get some track time at Road America. That's why I am looking into this stuff.
Old Apr 25, 2012 | 09:35 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
4 or 5 years ago I bought the goodridge lines for my 92. What a cluster, lines not marked (not even front or rear), Instructions were non-existant, lines too long, got them on, but rubbed thru a line just on the trip home! Put on a set of Earls - they were as close to perfect as possible. Had the same blocks on the caliper end as the stock lines, each line was clearly marked as to what end of the car and what side they went on! Unfortunately they don't make them any more
I'll be getting the DRM lines next time.
Old Apr 25, 2012 | 03:56 PM
CDN/AZ LT4's Avatar
CDN/AZ LT4
I installed a set of Goodridge lines this winter on my '96. Not to long, no rubbing and straight forward install.....and they work just fine.
Old Apr 25, 2012 | 05:14 PM
blkzr1's Avatar
blkzr1
Default ss brake lines
hi, contact shawn at corvettenutz.com or he is here on the forum as "onerarez16". he has them also. he is a great person to work with. see ya
Old Apr 25, 2012 | 08:50 PM
John A. Marker's Avatar
John A. Marker
I replaced my stock rubber lines with the Goodridge SS lines. No problems with installation or longevity. I would suggest that while you are doing this to get a couple of sets of speed bleeder (suggest Rock Auto). They are sold as a pair. This makes bleeding the system much easier.
Old Apr 26, 2012 | 06:35 AM
ffvetteman's Avatar
ffvetteman
Thanks for the info. So we're the lines you got marked as to which one goes where and were a good fit? I would not mind getting the Goodridge lines just because I can get them from Summit along with the pads I want.
To SS brake lines?
