MSD ignition
Old May 21, 2002 | 08:22 PM
grumpyvette's Avatar
grumpyvette
Default Re: (Glock'94)
the first one I mounted (still works great after 5 years) was on the firewall above and behind the power brake booster (youll need to dremmel two of the plastic ridges on the rear of the booster for slightly more clearance) on my neigbors 1985 vette we mounted it really high up in the passenger foot well in the cab to get it out of the engine head area, either place works but behind the brake booster is less trouble
Old May 21, 2002 | 10:00 PM
red-y's Avatar
red-y
Default Re: (grumpyvette)
Mine is mounted on the driver side of the rear compartment. Adjustments facing towawd the front. MSD digital 6.. :smash:
Old May 21, 2002 | 10:14 PM
jmrl98's Avatar
jmrl98
Default Re: (red-y)
Red-y, not to sound any more stupid than I actually am, but do you mean driver side rear engine compartment? :confused:
Old May 21, 2002 | 11:03 PM
96LT1's Avatar
96LT1
Default Re: MSD ignition (jmrl98)
Is yours under the driver's side headlight? I was checkin' it out, and it is rather tight with the cannister and everything! :seeya
Yes it is. I had to reposition :smash: it after trying to close the headlights the first time after the install. The headlights came up okay without rubbing but got hung up when closing.
Old May 22, 2002 | 12:45 AM
ROME's Avatar
ROME
Default Re: MSD ignition (96LT1)
I've got mine mounted on the top of the battery. It looks/works fine there. Makes it real handy as well :yesnod:
Old May 22, 2002 | 01:44 AM
RonRed89's Avatar
RonRed89
Default Re: MSD ignition (Glock'94)
I'm running the Accel 300+ and have had good luck with it. The only thing to watch out for in these systems is keeping them dry. The Accel has an inline fuse which blows if the box senses that its wet. (unfortunately I found this out. :-)). Other than that, with the ignition box and coil, the throttle response and MPG gain is noticible.
Mine is mounted on the passenger side brace right behind the passenger side wheel well.
I know that the MSD box is pretty popular, but I have no complaints about the 300+
Old May 22, 2002 | 11:22 AM
jmrl98's Avatar
jmrl98
Default Re: MSD ignition (RonRed89)
Ronred89, thanks for the insight. I'll explore the passenger side brace behing the passenger side wheel well also. :cheers: :seeya
Old May 22, 2002 | 11:25 AM
jmrl98's Avatar
jmrl98
Default Re: MSD ignition (ROME)
Hey rome, once again I'm showing my lack of brilliance, but do you mean actually on top of the battery, like as in drill into it?? :confused: :seeya
Old May 22, 2002 | 06:43 PM
HWoods's Avatar
HWoods
86 Vette, MSD 6AL installed in passenger side lower compartment below the headlight. Converted to Small Cap HEI MSD Distributor, I think part no. is 8366 and external dual connecter coil. I did have the MSD 6AL located on top of the battery secured by a 3" piece of velcro , one strip on the box and the other on the top of the battery. Worked great. A shop relocated my box without asking, but it works OK where it is, so I did not move it back.
Old May 22, 2002 | 06:45 PM
HSvett96CE's Avatar
HSvett96CE
You know, for those who have the Breathless Intake, I mounted mine right next to it (by the box) on top of the radiator shroud. Fits perfect, and no water problems when I wash my engine.
Old May 22, 2002 | 07:28 PM
ROME's Avatar
ROME
Actually, the previous owner of my car utilized a type of double-sided sticky strip to mount it on top of the battery. The sticky stuff looks like a long piece of Juicy Fruit gum, and it's just gummy enough to hold things solid without the disadvantage of the MSD becoming permanently affixed to the battery caps. There's plenty of room in that position, with the MSD tucked safely under the hood latch support. It sits solid and doesn't move at all, yet it doesn't pose any problems when its time to service the battery. I've got it mounted square on the back corner of my battery - see the pic.
P.S. - I took that thing off my water pump and hustled it down to the frisbee golf course last weekend for some late night fun :nono: :D
Old May 23, 2002 | 12:15 AM
RonRed89's Avatar
RonRed89
That engine looks nice!
How do you like that MSD distributor? I did try to get one of these units last year when I was having ignition problems (bad module) and the guy at Summit ended up shipping a unit with a mechanical advance which was incompatible with the car. I now see that MSD has a newer model distributor which will fit on the electronic HEI vehicles. Was this mod worth it for your setup?
Old May 23, 2002 | 03:34 AM
  #33
ROME's Avatar
ROME
That's actually a Hypertech Street/Strip distributor. I have had nothing but positive experience with this ignition setup. I bought the car with the ignition as it is now, and it's performed flawlessly for me. Seems pretty well bulletproof.
Old May 23, 2002 | 10:23 AM
  #34
Nathan Plemons's Avatar
Nathan Plemons
Eventually I'll install the MSD Digital 6. It has some nice features that I like. I don't expect any major HP gains, but rather it should just allow me to make the most out of what I already have.
Old May 23, 2002 | 11:42 AM
  #35
jmrl98's Avatar
jmrl98
Rome, thanks for the pic and the details!! I now can pursue several mounting options. :seeya And man, you've got a sweet ride, dude!! :cheers: :yesnod:
Old May 23, 2002 | 02:15 PM
  #36
jmr302's Avatar
jmr302
Default Re: MSD ignition (dgoodhue)
I took my tach filter out, but I am not getting a reading. I was having problems with the tach acting funny over 3000rpm (with just a MSD coil) and removing the tach filter helped it, but when I put in the MSD I lost the tach. It may have been the other way around, it been 2 years since my car was on the road.
When running an MSD6/AL you need to splice your tach wire into the white wire on the MSD harness. The MSD tech folks told me that leaving the tach wire connected at the distributor cap can fry your tach in addition to not working.
Old May 23, 2002 | 03:18 PM
  #37
jmrl98's Avatar
jmrl98
Default Re: MSD ignition (jmr302)
Thanks a lot, jmr302!! I'm sure that would've been a problem had you not given me this tip! Was it a "normal" splice, or were there other particulars? :cheers: :seeya
To MSD ignition
Old May 23, 2002 | 04:22 PM
  #38
jmr302's Avatar
jmr302
Nothing tricky, just splice into the wire. I had to make my own harness to mount the MSD box under the passenger side headlight, next to the rad overflow tank so I just spliced into that.
If you haven't done this sort of thing before I highly suggest getting familiar with a soldering iron and how to use it properly. Ditto for heat shrink and a heat gun. There are several very experienced electrical guys here and there are some soldering technique related posts hiding in the archives.
Life's too short to burn your 'vette down because some twisted-together wire connection failed or grounded on something.
Old May 23, 2002 | 10:42 PM
  #39
jmrl98's Avatar
jmrl98
I agree jmr302, thanks for the advice. :cheers: :seeya
Old May 24, 2002 | 12:21 AM
  #40
Hi-psi's Avatar
Hi-psi
This splicing of the tack wire you all are speaking of,....does this just apply to the L98 cars or the LT1 also? The instructions I have don't say anything about having to rewire the tach.
