Headlight motor!
Old May 20, 2002 | 09:00 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Default Headlight motor!
This bottle cap looking thing keeps spinning for a few seconds after my lights pop up or go back down, also the headlight motor makes noises during those seconds. Sometimes this headlight doesnt even popup all the way. Why does it do this? My other head light doesn't do this, it just spins until the headlight pops up and stops.
I have a lazy eye :sad: or crazy eye :crazy: arrrr :mad
Old May 20, 2002 | 09:14 PM
r_hinks's Avatar
r_hinks
Default Re: Headlight motor! (Dudeurgettnavette)
There is a repair kit for this. Three bushings costs about 5 to 10 bucks. Its kind of a pain to replace though its worth it. You would have to remove the entire headlight, take the motor apart to replace the bushings.
I went to the following site to replace mine.
http://www.combatshots.com/
It took me aproximatley 3 hours to do one but when i do the other one it should only take about an hour at the most
:cool:
Old May 20, 2002 | 09:54 PM
Dudeurgettnavette
Default Re: Headlight motor! (r_hinks)
:D Thanks :seeya
Old May 20, 2002 | 10:58 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I just did mine last weekend... I kept hearing that it is a pain but it was not bad at all. It took me two hours to do both and be back on the raod.... 6 blots and unplug the wires this will get the headlight out... 5 number 27 torks bolts to get the motor off the head light and drive out the pin on the arm (when you get it apart you will know what I mean) then just follow the instructions with the bushings.... Piece O Cake.... E-mail me if you need any help... :cheers:
To Headlight motor!
