Solid rear axel or upgrade IRS?
)Most of the racers in the past here have noted, that a properly built Dana 36 will run 1.7's without issues, once you go into the 1.6's and 1.5's, it becomes moment by moment thing. The Dana 44 can run 1.5's fairly reliabily with an auto. (I have somewhere around 1000 1.5's on mine with no issues), but once they go into the 1.4's and quicker, its a hit and miss thing. Any low 11 second car is capable of eeking into the 1.4's, hence it becomes a real issue with 10 second cars, which all are capable of running 1.4's and even into the 1.3's if you're launching appropriately.
But, I'll never say something can't be done, I guess with enough money and know how, somebody could make one last reliably for 9 and 10 second cars.... I just haven't seen it. I will add, for the rare occasion you do see somebody running fast with a Dana 44, what you don't know, is that they have broken it and rebuilt it 1/2 dozen times already...... I think its cheaper in the long term to just go Solid.
As a note, I do not think a Solid Rear takes away from a C4 in anyway at all.... if anything, it actually adds value to those in the know. Given the choice, with what I know today.... show me a high power vette with an IRS and one with a Solid and I'll buy the Solid, even if its more money.
If you drive it on the street/road race it?
Not worth the effort, as you rarely launch the car hard like in the 1/4.
Take it to the drags religiously? Yes...worth every penny to convert it to a reliable rear diff.
Like I said earlier...I've been looking at the Viper D44 for my ZR1 racer. There are TONS of the Vipers out there running fast times (some in the 8 second territory) running the STOCK D44 IRS.
The issue with the C4 IRS is the casting...not enough beef in the pinion area to keep it from flexing and breaking. I'm sure you know this intimately already
They don't have that issue with the Viper.
Beefy, stronger than King Kong...and so I intend to buy one and see how tough it would be to modify the C4 chassis to accept the carrier that the Viper D44 has.See...I road race (predominately) but like to do the occasional 1/4 mile drags so in MY case, the IRS is required and making it bullet proof is the goal.
It all comes down to your 85% use rule of thumb. Build it for what 85% of your intended use is...
If you want to drag race (mostly) = solid axle conversion
If you street drive it and occasionally drag race = IRS beef up
If you decide to drag it more after you beef it up, after the first major breaking of the D44 go directly to a solid rear, do not pass go, do not collect another $3500 to fix the D44.
Not sure, maybe you meant to quote somebody else's post.... I don't know.
If the OP is going to HEAVILY drag race the car...then yes, a solid rear end is the way to go...as everyone has been suggesting.
If they only occasionally drag race, and like the performance the IRS gives on the street/track carving corners then a solid rear is NOT the best thing to do.
Ideally, something that could be easily swapped out would be the way to go but that isn't going to be an easy solution (or cheap).
One of the guys from Tiretown had his C4 set up that way...and he would come to NCCC convention with the IRS (and the 6-speed) installed in the car for autocross.
Then after that was done they would wrench all night, swapping out the rear AND the trans (to an automatic) and do drags.
Seemed like WAY too much work to me...I think I'd have just stopped at the rear end and been done with it.
It all comes down to what the OP WANTS to do with the car and where they think the money should be spent...
I don't particularly like how a C4 Corvette rides and handles curves with a solid rear. Been in a few of them now and can honestly say my Z07 will eat them for lunch on a track.
But then again I rarely take mine to the 1/4...and so that is where the value (for me) would be NOT to put in a solid rear.
Bear in mind, he has a 800-900 HP motor.... he also stated he goes to the track only twice a year, because he knows the carnage is coming..... hinting, he would like to go much more often if he had a reliable rear-end.
For what its worth, I agree, if you're autocrossing, a solid rear isn't necessary. Just not sure what that has to do with my post.
Id rather have the c4 (w/ irs) running 8.97 then a solid axle 5.0 running 8.60
-or-
Id rather have aaron at aks racings car running low 9s w/ an irs vs. His car runnng low 8s w/ a solid rear.
Its clear we disagree and I'm sure we can agree at that.
The op needs to be aware that there are different ways of thinking.
Lots of aftermarket support for go fast parts.
But all the 5.0 guys like my 87 C4 A4 roadster.
Its something different to them.
Owned it 5 years now too.
Paid off & its all mine.
Sorry you disagree.
I have already destroyed several new Half shaft 1350 Spicer U-joints.
They don't last long with my right gas foot planted hard.
Solid axle & 4- link Competition Engineering Pro Magnum 4130 Chrome Moly construction.
Completed by myself.
Good luck with yourC4 IRS & drag racing hard.
P.S. All 1953 to 1962 Corvettes had a Live Hotchkiss Solid Rear Axle Differential.
I drove a 1958 a few years back.
Daul Quad 4-speed.
Top down in the sun.
Ran it hard.
Had plenty of character & personality only a Corvette could have.
I'd consider purchasing that if one existed.
You can imagine what the cost would have been...a solid block of billet aluminum the size of the pumpkin? The (many) days of machine work to whittle it down?
When I asked him about it last year he just laughed and said the price point was too high to even make it worth their while.
Sorry you disagree.
Daul Quad 4-speed.
Ran it hard.
Which is why I'm looking at a Viper D44 conversion for the race car.
You can find them on that auction site for about $1000 all the time...
I've been looking at the Viper boards for some time and rarely see complaints of "breakage" on them...even in those 1000+ HP turbo versions doing 8's & 9's in the 1/4.
Of course, the C-beam will have to either go or be modified to fit. Lots of things to think about and modify.
It won't be a cake-walk but it will be fun
Should keep me out of trouble for the next year
