overheating problems crate motor
Old Apr 30, 2012 | 05:05 PM
infernoman's Avatar
infernoman
Default overheating problems crate motor
having problems with overheating on an 1984 corvette with original injection system. Im having problems with the water pump and i need to know which rotation comes originally with the engine and which rotation i need. im running a standard v belt setup with alternator on the passenger side no air pump and no a/c. one belt running from crank around alt and waterpump.
Old Apr 30, 2012 | 05:30 PM
trackbird's Avatar
trackbird
That should be a standard rotation pump.
Old Apr 30, 2012 | 07:01 PM
infernoman's Avatar
infernoman
That's what I was thinking aswell. Which pump would I have to get to retain the old alternator bracket to water pump with a standard rotation. I've been reading that the water pump for the c3 would work and have the standard rotation true ?
Old Apr 30, 2012 | 07:18 PM
trackbird's Avatar
trackbird
If the water pump and the crank pulley spin the same direction, its standard rotation. A C3 pump will be a "short" pump. You'll need to know if you have a short or long pump. If you have a short pump it will be right against the timing cover (you might be able to slip a credit card in between the timing cover and the back of the water pump. If you have a long water pump, you will see a gap that's roughly 1/2" (or a bit less). Then we can figure out which pump you need.
Old Apr 30, 2012 | 07:28 PM
infernoman's Avatar
infernoman
I know the corvette has a short water pump I'm just wondering if the c3 has the standard rotation pump that I'm looking for. Also it doesn't matter whether the pump is long or short style just need the standard rotation preferably with the older style alternator bracket on passenger side
Old Apr 30, 2012 | 07:49 PM
infernoman's Avatar
infernoman
theres a picture of the setup im using
EDIT: it doesnt seem to be showing up on my computer if it doesnt work the link is http://imageshack.us/photo/my-images/85/photodum.jpg/
Old Apr 30, 2012 | 08:34 PM
383vett's Avatar
383vett
The water pump for an 82 Corvette is the one you are looking for. It'll bolt right up and has the standard rotation since you are no longer running the serpentine belt.
To overheating problems crate motor
