1989 Carpet Help?
Old Apr 30, 2012 | 06:32 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
Default 1989 Carpet Help?
On my 1989 corvette I just finished installing almost all the carpet all I have left is the part under the dash on the passenger and drivers side about where your knees would be and where the floor mats would go.
I can not figure out how to take off the panels on the driver and passenger side near your knees so that I can replace the carpet on it.
Any help would be appreciated whether it is a video on how to or just some instructions.
Also just wondering what are the best kinds of spark plugs for a 1989 corvette? I need to replace mine and want better than what i have as the ones I have now are not that great.
Old Apr 30, 2012 | 08:10 PM
Gear Jammer's Avatar
Gear Jammer
Active Streak: 90 Days
On my '91, the knee-bolster carpet was glued on. PITA to remove; I used a heat gun (very carefully) along with the 3M adhesive remover. Not fun, its messy.
Old Apr 30, 2012 | 08:25 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
I know how to remove the carpet just not how to get the panel off so I can actually remove the carpet.
SunCr's Avatar
SunCr
Passenger side is held on by 3 machine screws. Driver's has 2 and then a pinch washer near the accelerator which you can pry off with a flatbladed screwdriver. Once you've got the pads out of the vehicle, it should be easier to glue on your new pieces.
Stock plugs are fine and should last for 100,000 miles on any vehicle with electronic fuel injection assuming no one has dumped leaded fuel in it and it hasn't sucked coolant through a head gasket leak (all too common on the '89). Removing them will often tell you if there's a problem. Rust on the threads, particularly at #7, means it needs more than new plugs. Heavy fouling, the rings or valve guides are shot. Lot's of soot, it's probably sucking air from somewhere other than the MAF making it run too rich. If one is sparkling clean and the others aren't so great - see 1, it's sucking coolant.
When you do the plugs, you might want to remove the a/c compressor for a straight shot at 2 & 4. You'll need to unbolt the Accumulator too and just move everything in one piece out of the way. You don't have to discharge it as there's enough flex in the hoses to move it.
Old Apr 30, 2012 | 08:29 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Do you think you could take a picture or try to explain where the screws are?
On the spark plugs I need to buy new ones as all of them but 2 are beyond repair and I was wondering what was the best kind to buy.
Old Apr 30, 2012 | 08:55 PM
nova power's Avatar
nova power
I just finished my 1987.The drivers side I could remove found locations of screws.But the passenger side no.I replaced the carpet without removing it.
Old Apr 30, 2012 | 09:22 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
This is what I was thinking of recommending.
SunCr (though normally spot on), is wrong about the PS carpeted panel removal. It's a PITA, a ROYAL pita. (I believe he's thinking of the plastic hush panel (further behind the carpeted piece).
There are 4 bolts (studs) that point up into the (under) dash. There are 4-bolts that require removal to get it down/off. Even when/if you get to the bolts, it's not easy to pull it down and push it back up.
I'm not really dramatizing, I really didn't care for this panel's mounting method...It's a friggin' vanity panel...not motor mounts!
To get to the 4-bolts, I finally had to remove the bread box. Even that's a pita to get off -- requiring a loose hack-saw blade to cut thru it's bracket. (per instructions that came with a flat-panel replacement)
I vote (for your sanity) to pull that carpet off as the panel is mounted. You'll be much happier -- even if you have to mask off/spray whatever glue you're using for mounting.
Old Apr 30, 2012 | 09:31 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
What about the driver side? Also I was not going to use spray glue as it is not as good, I was gonna use 3M Fast Tack Trim Adhesive (08031).
Old Apr 30, 2012 | 10:55 PM
caddyboy84's Avatar
caddyboy84
Default Wow!!
I've been following your threads and you're really doing a lot of work to your car
Old Apr 30, 2012 | 11:08 PM
GREGGPENN's Avatar
GREGGPENN
Good. If that's like brush-on contact cement, it should work well. Still, you should consider an in-car application -- to save time/work. If you want to go for it...
The DS is held on by several points IIRC. There are two screws imbedded in deep recessed "tubes". The carpet fiber will tend to hide those two recessed holes. But, they are at least 1/2-3/4" and can be felt if you use your fingers. They are either small hex or philips head. Use a flashlight to decide.
You have to remove the hush panel (rear plastic panel) first.
I'm thinking there's at least two screws that go in from the outer end of the dash (below the defroster donut.
Finally, I think there's a screw on either side of the steering column -- near the front edge of the knee pad.
Old Apr 30, 2012 | 11:49 PM
caddyboy84's Avatar
caddyboy84
I've had mine out more than once and don't even remember how I did it I remember it being pretty quick and easy though.
Old May 1, 2012 | 12:08 AM
caddyboy84's Avatar
caddyboy84
In my opinion, the best contact cement is Dap in the red can, it's a brush on cement and that stuff is the best and I've used them all. I've done tons of interior work on cars and boats and the one thing thats gonna make a big difference to the way the carpet will stick, is if it's bound on the back. The carpet should have a thin plastic coating on the back, it the carpet is "raw" it will tend to soak-up the glue and not adhear well. What I used to do is use cove base cement on the carpet backing and let it dry, that creates a hard rigid backing and makes the carpet stiff. This gives the carpet the backing it needs for the contact cement to grab onto.
Old May 1, 2012 | 01:11 PM
SunCr's Avatar
SunCr
Holy Crap! Never had an issue taking these panels off - maybe because it's an '89 and that means at least 2 or 3 ECMs (hell, I had 3 replaced under warranty!). Anyway, they're 8 mm sheet metal screws so get the seat all the way back, lay on your back and you should be able to find them. As you drop it down you're going to have to disconnect the courtesy light, but that's fairly simple too.
As I said on plugs, stock AC Delco is fine. There are no miracle plugs and the tech is to have a clean burn so that they last. Just be sure that you've got good access or your next post might be - how do I repair a cross threaded plug hole?
Old May 1, 2012 | 01:25 PM
SunCr's Avatar
SunCr
Sent you a PM but finally realized you're doing the carpet which means a whole lot more comes off - I've been referring to the plastic hush panels, which I would remove anyway. From there, it's dropping the column, removing the dash trim, upper panel and Bread Box which is a pain to access (as Gregg pointed out). You're also going to be removing some of the a/c duct work, but that'll give you an opportunity to seal it up with some duct tape so that your a/c isn't blowing on the ECM (factory seals were foam and it's usually long gone). For me, I just take off anything that's in the way until it's easy so I think its a matter of what makes it easy for you.
To 1989 Carpet Help?
