Hi...I have a 90 with 24K miles that has a a bit of a skip at low RPM...it seems to go away at WOT...but when you are driving at a consistent low RPM (under 2K) it feels like it is mis-firing.
I changed all o the injectore last summer ( under the tutalage of Jon at FIC...thanks )...and all new plugs were put in about 500 miles ago...
What is your fuel pressure? I had a slight skip/hesitation under load at lower rpms and it turned out to be the fuel pump was beginning to go south. If yours is consistent and more than just one skip, i would look more towards the ignition system.
As previously posted, have a similar problem with my 87 A/T. Seems most likely to happen in 3rd at 1200 rpms or so, but goes away if I start to accelerate. Have new plug wires and have replaced the three ignition components in/under the distro cap. Suspose plugs are next but was hoping to get some confirmation here on the forum. If it was a stick-shift, I say it feels like I forgot to shift and am lugging it--too weird.....
