Solid rear for 89
Old May 2, 2012 | 07:09 PM
black_89_vette's Avatar
black_89_vette
Default Solid rear for 89
Seriously thinking about his for next year.
Thinking about Carroll's Rod and Racecraft drop in unit.
These units come with a spool and I heard that spools are def not fun in the street.
I have (in the past) limited my trips to drag strip due to breakages and the likelihood of them.
If my engine is right at 500 hp / 500 tq and I plan on spraying a 250 shot, I still want to do the solid rear route, but what other options should I be looking at in regards to the spool?
I very much want to keep this streetable but don't want to continue to break parts as I have in the past.
89 383 ZF6 D44
Old May 2, 2012 | 07:17 PM
pologreen1's Avatar
pologreen1
Old May 2, 2012 | 07:58 PM
383vett's Avatar
383vett
A 12 bolt rear can be ordered with a posi or a spool. They both fit inside the carrier. If you have a street/strip car, go with the posi.
Old May 2, 2012 | 08:56 PM
impact1968's Avatar
impact1968
I like the picture of the smoke cloud building from the back of your 89.
Old May 3, 2012 | 12:15 AM
black_89_vette
Ok cool. Good to know.
383vett , bolting on slicks and releasing clutch (McLeod Street Twin) on a 2 step set to probably 4K or so (just guessing), will the spool be a LOT less likely to break than the posi?
impact1968 Thanks, that was a still from an old vid I shot. Engine was around 375 hp then. http://video.google.com/videoplay?do...03090290661814
Old May 3, 2012 | 12:37 AM
rodj's Avatar
rodj
Jessie had a spool in his D44
http://forums.corvetteforum.com/1547395714-post1.html
http://forums.corvetteforum.com/1547404130-post10.html
before he did the solid swap
Old May 3, 2012 | 10:54 PM
DVNCI's Avatar
DVNCI
Detroit Locker in mine, I didn't want a spool
All the advantages of the spool, none of the downsides
That being said, make sure the car is pointed straight before you hit the gas (same thing with a spool)
Only bad thing is the Locker's "click" quite a bit when they start ratcheting around a corner, but I would rather hear that than tires chirping with a spool
Old May 3, 2012 | 11:36 PM
383vett's Avatar
383vett
Posi's are tough. Just have to make sure both tires are wet and to avoid the one legged burnout. That'll kill it quick. I have a spool but my car is a track only car.
To Solid rear for 89
