Loose Rag Joint
Old May 3, 2012 | 08:19 AM
jmgtp's Avatar
jmgtp
Default Loose Rag Joint
I've had a slight amount of freeplay in my steering wheel since day 1 of owning the car. I was never able to find play in tie rods, ***** joints, etc. I happen to have the headers off and found that if I wiggle the steering shaft I could feel the movement but more importantly I could SEE it in the rag joint. It looks like where the 2 bolts go through the 'rag' has become wallowed out.
It looks fairly simple to replace. Just 2 bolts if I'm not mistaken. But, I can't seem to source a replacement locally. Is this part available, or is the solution to replace the whole shaft?
Old May 3, 2012 | 09:31 AM
Churchkey's Avatar
Churchkey
NAPA may still carry replacement isolator rings. Don't know if they will work on a Vette, never tried but have install a # of them over the years.
Use a line up mark on both shafts to aid reassembly, the steering wheel could end
up 180* off center.
Old May 3, 2012 | 04:39 PM
StealthLT4's Avatar
StealthLT4
It's not that bad to replace, really. Hardest part was finding one; ebay ended up being the only place for me. Apparently they don't make them anymore, so NOS ones are incredibly expensive. Search ebay for used.
Old May 4, 2012 | 08:29 AM
techvette's Avatar
techvette
I noticed this on my car, too, last year. I replaced the whole intermediate steering shaft. Corvette Central is the only Corvette parts house I found that sells them. $150 or so.
Old May 4, 2012 | 02:09 PM
jmgtp's Avatar
jmgtp
Is the rag joint a safety mechanism? Is it meant to shear in a violent front end collision so the steering wheel doesnt rip your arms off?
Or, does it just reduce vibration in the steering wheel by isolating it from the R&P?
If just the latter I might look into putting a bolt through it.
Old May 7, 2012 | 11:02 AM
redrose's Avatar
redrose
84/85 didn't even have a rag joint...WHY? (i dunno)
To Loose Rag Joint
