targa repair
Old May 3, 2012 | 07:51 PM
stevebrochu's Avatar
stevebrochu
Default targa repair
i have a decent size crack in my top. i am planning on wrapping it with carbon fiber. looks real nice when done right but i need to repair the crack first so it won't get any worse. anybody know how to repair the crack so the top will be solid?
Old May 3, 2012 | 09:25 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Don't know how or if this will work on a targa top ..http://www.youtube.com/watch?v=hT6Ow_cBTps
Old May 3, 2012 | 09:41 PM
The Plastic Lizard's Avatar
The Plastic Lizard
Are you using real cf or dinoc?
If using real carbon fiber the cf will dry stronger than the plastic so repairing the crack is unnecessary. If using the vinyl that looks like cf you do need to repair the crack. I repaired mine with superglue. It held for a good long time so far
Old May 3, 2012 | 10:24 PM
oldalaskaman's Avatar
oldalaskaman
heat a plastic sheet the size of your inside frame, mold it in the bottom and glue it down, super solid and still not to heavy
Old May 5, 2012 | 07:50 AM
chuckiede's Avatar
chuckiede
5th Gear
Default Crack
The crack in mine is clear through. I can stick paper throuh it. It's dead center of the roof, from the windshield back about 9". Think the crazy glue will hold? Did you a clamp on the top to compress it? Someone else said to drill a very small hole at the end of the crack to stop it from spreading.
To targa repair
