EXPERIENCED engine builders,, help!
Old May 4, 2012 | 10:49 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default EXPERIENCED engine builders,, help!
Guys I have a problem with my '85 L98 that has me completely baffled. I have had a ticking sound like a loose rocker(s) now for quite some time. I have set the rockers at least a dozen times and have never found one not right. I finally decided it must be a lifter so I bought a complete cam & kit to replace everything. I do NOT just throw money at my car, I wanted to do this change anyway. I have the later aluminum 128 heads on my car which have the small pushrod holes & guide plates. I am running a set of the old Crane Energizer non-self aligning full roller rockers 1.6 ratio that are in perfect condition and I have set preload anywhere from 1/4 to 1 full turn. At 1 full turn the car would not even start. Anyway, after the cam change along with new lifters, springs, retainers, & locks I still have this damn noise. I have even changed back to the stock rockers but the noise is still there. I have also checked pushrod length and installed proper length p-rods. Any ideas at all??
Old May 4, 2012 | 11:03 PM
cv67's Avatar
cv67
St. Jude Donor '05
Was the cam stock before, what is it now?
Remove the belt on the accessories and try to start it?
Check for exhaust leaks? That one can fool you. Check the EGR tube going to the intake too.
Old May 4, 2012 | 11:18 PM
Midnight 85
No, cam was a very mild Comp, it now has a Summit cam which is just a bit more than the Comp.
Took the belt off tonight, no change.
No exhaust leaks that I know of but I will check that tomorrow, and no EGR.
Old May 4, 2012 | 11:23 PM
red L98's Avatar
red L98
What kind of oil pressure you reading ?
Old May 4, 2012 | 11:25 PM
Midnight 85
43, hot at idle.
Old May 4, 2012 | 11:46 PM
cv67's Avatar
cv67
St. Jude Donor '05
No intereference with retainer to guide? Would be hard to believe a broken spring on both sets Id count that one out.
Old May 5, 2012 | 12:37 AM
Midnight 85
No wear marks on anything, old springs were good, just put new ones on.
I am suspecting that the Valve Stem Tips are no longer square.
At exact 90 degree flat angle in relation to valve stem.
That would cause a similar or exact sounding lifter noise.
Sometimes reground incorrect by engine rebuilders.
Their valve grinder stem resurfacer is out of wack.
Seen that several times in the past.
Or the engine rebuilder machinist does not even regrind the valve stem tip after a valvejob.
B
Valve tips look good no signs of enevenness or wear of any kind. Wouldn't the full roller rockers negate any irregularities? You really have me wondering about the exhaust gaskets now. I will never figure out why header manufacturers don't make the openings to match the heads. My 128's are the factory, small square ports while my Hedmans are round. I'll get back to you tomorrow on what I find. I do know that if they are leaking they are doing it on the bottom side, I've been up close & personal with this engine now for a week.
Old May 5, 2012 | 02:15 AM
Midnight 85
I'll check them out first thing tomorrow, I know I sure as hell can't get under my car,,,, even if it is raised up a bit.
Had some real thunderboomers last night, I don't normally get seepage in my basement but I did last night. Supposed to get it again today, (saturday)
Old May 5, 2012 | 03:04 AM
Crepitus's Avatar
Crepitus
I would try to find exactly where the noise is coming from. get a automotive stethoscope or a long screw driver pressed to your ear and the engine. also a 2' piece of heater hose like a megaphone. once you find where the noise is coming from it will be much easyer to diagnose.
Old May 5, 2012 | 07:11 AM
ProjectC4's Avatar
ProjectC4
On a customer's stock 350 I once had a valve tap that would not go away. Adjusted lifters, moved rockers around, the same valve kept making noise. It was a bad stud. Pulled the stud out by using a deep socket and washer over the stud then tightening up with the nut to pull it out of the head. Stud did not look bad either. Weird.
Old May 5, 2012 | 07:43 AM
Churchkey's Avatar
Churchkey
Probably a worn valve guide, it will sound like a lifter tick.
Check one cylinder at a time, both valves closed, use a long screw driver in the head valve cover rail & lever the retainer while watching the valve stem. Stem movement & worn guides will be apparent.
Last edited by Churchkey; May 5, 2012 at 07:45 AM. Reason: got coffee, corrected spelling
Old May 5, 2012 | 08:50 AM
Midnight 85
Aluminum heads = screw in studs, but thanks anyway.
Thanks, I'll check this out but I'm 99% positive they are good.
Old May 5, 2012 | 08:52 AM
Midnight 85
Originally Posted by gsdave
Why don't you just post under your real user name?
Hmmm, now that you mention it.
Old May 5, 2012 | 08:59 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Because he was banned for getting into pretty heavy with a vendor. Apparently he's been given somebody else's info to continue to post.
He was temp. banned before a few times before he got the big boot.
Old May 5, 2012 | 09:57 AM
Caboboy's Avatar
Caboboy
Injectors can make a ticking sound like lifters, you can use a stethoscope or piece of tubing to check.
Old May 5, 2012 | 10:05 AM
TTOP350's Avatar
TTOP350
Put the stock rockers back on.
I have had many older crane rocker sets sound loud. Had a few customers what them removed. They brought them to me sooo I had to charge to R&R 2 times but they didn't like the ticking/tapping at all.
Old May 5, 2012 | 10:10 AM
cv67's Avatar
cv67
St. Jude Donor '05
You know what it could simply be the injectors ticking away.
They can fool you and sound just like a loose rocker arm.
Churchkey chasing a similar noise on mine...worried a guide could be bad. Have to check that one out. They were imo loose when it went back together thought the machinist swore they were within spec. Hmmm.
To EXPERIENCED engine builders,, help!
Old May 5, 2012 | 10:39 AM
Churchkey's Avatar
Churchkey
Did all the heads when I worked for Ford, 302 & 351 Windsor V8's & some 240 6cyls would wallow out the stem bores. No guides in those iron heads. Fix was to bore them & install valves with oversize
stems of .003, .015 or .030 dependent on wear.
113 heads on my 89 lost #5 exhaust guide @ 110K, Installed new heads. Might have been #7 exhaust, don't recall exactly its been 10+ years & that ride is long gone (regretfully as it was the best of 3 Vettes).
T. Wayne Nelson's Avatar
T. Wayne Nelson
That's what I was going to suggest. They are louder than one would think....
Old May 5, 2012 | 10:57 AM
cv67's Avatar
cv67
St. Jude Donor '05
Will check it Churchkey.
These damn Dart heads have eaten so many guides in a short period of time its not even funny.
No matter how perfect you make the geometry they still go away fast. God I hope thats not the case. lol
HAve to lash them this morning so Ill find out.
