6 speed ZF fluid..
Old May 8, 2012 | 06:35 AM
lucky1357's Avatar
lucky1357
Default 6 speed ZF fluid..
I'm sure there has been many threads on this but tried to search and got no results. Whats the best oil to use in the ZF.....I have a 93 LT1 and am replacing the oil in it......
Old May 8, 2012 | 07:06 AM
LD85's Avatar
LD85
Not many, hundreds
www.zfdoc.com
a few from the search engine from last few months
http://forums.corvetteforum.com/c4-g...bmw-fluid.html
http://forums.corvetteforum.com/c4-t...f-6-speed.html
http://forums.corvetteforum.com/c4-t...nsmission.html
http://forums.corvetteforum.com/c4-g...il-change.html
http://forums.corvetteforum.com/c4-t...ion-fluid.html
Old May 8, 2012 | 07:40 AM
rithsleeper's Avatar
rithsleeper
Amsoil syncromesh
Old May 8, 2012 | 10:19 AM
CDN/AZ LT4's Avatar
CDN/AZ LT4
Originally Posted by rithsleeper
Amsoil syncromesh
Agreed, there's a very friendly supplier on this Forum who have it shipped to you within days....think about getting Amsoil brake fluid, and diff fluid while you're at it and save on shipping.
Old May 8, 2012 | 11:17 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yes, there have been many threads.
The answer is always the same, you will never get everyone to agree on what is "best".
You will get multiple opinions of what everyone else uses.
So, with that said I will tell you I use Amsoil in my '96
Old May 8, 2012 | 12:22 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Here you go:
AMSOIL
Manual Synchromesh Transmission Fluid 5W-30
http://www.amsoil.com/catalog.aspx?G...212?zo=1934716
Old May 8, 2012 | 03:36 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Originally Posted by Kubs
Here you go:
AMSOIL
:agree:
Old May 8, 2012 | 07:12 PM
93Rubie's Avatar
93Rubie
At lot of guys run the Amsoil Syncromesh and it seems to be good.
A few others and me included run the Redline Lightweight Shockproof Gear Oil aka Smurf Blue. It is a little stiff when cold, but butter after a few minutes. No complaints, this stuff will protect your box.
I'm sure you will be happy with either product.
Old May 8, 2012 | 07:17 PM
96GS#007's Avatar
96GS#007
I use Smurf blood in mine. Thousands of road course miles over the last 10+ years and no issues [knock on wood]
Old May 8, 2012 | 08:39 PM
lucky1357's Avatar
lucky1357
Thanks for the help....any imput on the royal purple...??
Old May 8, 2012 | 10:46 PM
Black89Z51's Avatar
Black89Z51
C5 guys have problems with it seeping through the paper gaskets and leaking.
Old May 8, 2012 | 10:50 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I may have said this before but a redline phone rep recommended against using lightweight shockproof in the ZF6. They say MTL is the correct Redline replacement...
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
But, I use the Amsoil and find it as good/better than the stock lube.
Old May 9, 2012 | 06:57 AM
grandspt's Avatar
grandspt
I just changed the fluid on my 1996 GrandSport as the shifting was getting a bit notchy.
I used Amsoil and my transmission shifts a lot easier, I am very happy with it. Also got some shrink tubing (to cover the open connectors) and disconnected CAGS after 15 years of living with the damn thing.
I am much happier with the shift quality now.
Old May 9, 2012 | 10:33 AM
rithsleeper
Well i ran royal purple ant it was ok but not nearly as good as amsoil.. also did the pensoil thing, ok but not like amsoil
Old May 9, 2012 | 07:51 PM
lucky1357's Avatar
lucky1357
ok....settled.....I ordered the Amsoil today
Old May 9, 2012 | 08:08 PM
93Rubie's Avatar
93Rubie
IDK, but 96GS#007 has certainly proven it to work. I guess the MTL would work too. I know of a guy who uses the Shock Proof, changes it every 15K and has it analyzed. Always comes back clean. To each his own as long as it works.
To 6 speed ZF fluid..
