88 Convertible Top Install
Was hoping to start a bit of a restoration on my 88 vert it really needs a lot of help I must say... Does any one have instructions on how to remove and replace the convertible soft top fabric? Looking to do it on my own in the next month or two.
Any advice or has any one managed to do it in the past?
THANKS
THANKS
I'm gonna rebuild the cable system with bicycle brake-cable parts, which I think will come out mint. I already bought the parts and am planning on doing it Saturday morning. It seemed that it isn't a cable that controlls the release, it's a thin steel wire and it's the brittle plastic wire housing that breaks, not the wire itself. Bicycle brake cable housings seem to be a perfect match for a repair. I found a similar replacement cable set-up for a later convertible but it's almost $100 and I think thats ridiculous for about $5 worth of plastic and wire. I'd like to change my top to red, but I have a reasonable local guy who does work out of a small garage close to my house, so I'm thinking I'd have him do it. I'm not sure it's something I'd want to teach myself as I go, but I'd be willing to try it if it's something not that difficult, considering the top is pretty cheap.
This situation reminds me of window regulators I've fixed on various cars over the years, the car builders used BIKE CABLES!! Because that's what they are, BIKE CABLES!! I remember when cars used big gears to operate these things and even if an old car drove off a cliff and the window broke the motor would still go up and down. I still can't believe that on a 1988 car, the top-release would be operated by $2 cables and not power solinoids like the hatch release
. I had to use a couple of plastic wire hold-downs from Radio-Shack along with my bicycle cable parts. I re-used the factory steel wire and just re-covered it with the bike break cable covering. This is how I did it: I removed the locks from the deck, then un-hooked the wire and straightened it out with Vise-Grips. Then I disconnected the plastic hold-downs (or what was left of them) and slipped everything off. I kept two factory "hooks", both at the lever-pivot. I had to make two new hooks at the lock ends, ya gotta try and keep the wire length as close to original as possible. I re-used two factory plastic hold-downs closest to the lever, because they were good. If they weren't, I would've used another two plastic wire hold-downs. There are two plastic adjusters for each side and they are a three piece unit. I re-used the larger side of the adjuster body and replaced the shorter end with a bike brake cable adjuster, it all just screws apart. You'll see as you take it apart. I took 9 pictures of everything that I can send everyone who asks. If you had a bike as a kid (or still do) this is pretty easy and it came out better than factory.
. I had to use a couple of plastic wire hold-downs from Radio-Shack along with my bicycle cable parts. I re-used the factory steel wire and just re-covered it with the bike break cable covering. This is how I did it: I removed the locks from the deck, then un-hooked the wire and straightened it out with Vise-Grips. The I disconnected the plastic hold-downs (or what was left of them) and slipped everything off. I kept two factory "hooks", both at the lever-pivot. I had to make two new hooks at the lock ends, ya gotta try and keep the wire length as close to original as possible. I re-used two factory plastic hold-downs closest to the lever, because they were good. If they weren't, I would've used another two plastic wire hold-downs. There are two plastic adjusters for each side and they are a three piece unit. I re-used the larger side of the adjuster body and replaced the shorter end with a bike brake cable adjuster, it all just screws apart. You'll see as you take it apart. I took 9 pictures of everything that I can send everyone who asks. If you had a bike as a kid (or still do) this is pretty easy and it came out better than factory.The Best of Corvette for Corvette Enthusiasts
Give me a personel message and your E-Mail ad. and I'll send them to you, or if someone has snapfish or whatever crap it takes to post them in a thread, I'll send them to you and you can post them. There right there in MY Garage.
I have an 87 which I did a new Top on a few months back. Removing the top wasn't too bad, but installing the new one you should really have someone assist you. Also ensure you get new weather stripping and install it. One problem I have and haven't resolved yet, my passenger window doesn't rest against the weather stripping on the vertical piece, about 1/4 gap between glass and rubber so i need to adjust the window. But the car is in the garage and undergoing a motor upgrade so no rush for me to fix.
Another thing I didn't like about the entire job is the rear bow. I couldn't find any clear instructions on what to do with attaching the top there. I ended up stretching the top and trimming the material back then I glued it on both the bottom of the bow where it wrapped over (not a lot of room because of weather strip) and I also used a lot of glue on the top surface of the bow where the material came over top to wrap under the bow. Not sure if that is how to do the bow, but it seems to have worked.
It can be done and will look good when your finished, best of luck...
My car has been sitting for quite a long time and the top is in shreds so I am going to be attempting to complete the job in a short while. I still need to get the seals for it.
I will make a thread as to how it goes when I get going.
I went on line and called everybody and only one place actually had them, Eckler's. I'll have them in three days, they told me they recently recieved a load of them, so if anyone needs them you know who has them
