93 clutch cykinder
Old May 14, 2012 | 05:55 PM
A88FXRS's Avatar
A88FXRS
Default 93 clutch cykinder
1993 lt1 6 speed. where is the clutch master cylinder located ?? real soft pedal that is almost to the floor. first thought is low fluid in resv.
Old May 14, 2012 | 07:28 PM
94z07fx3's Avatar
94z07fx3
Pull the battery and you can get to it or pull the computer and you can get to it top down. Don't get brake fluid on the paint. Remember these clutch reservoirs will fill as the clutch wears just the opposite of brake masters. The fill mark on the res is with the hat installed and expanded. The hat is also opposite of a brake hat in that you do not compress it before putting it in.
