VE Baseline - Help needed
Old May 15, 2012 | 08:53 AM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Default VE Baseline - Help needed
Hello,
Looking for some help with a baseline VE table on this engine.
355 cid
Dart 180CC heads
Comp 07-503 Cam
11.1:1 CC
Long tube headers
52mm t-body
I am running LT1 Edit, number don't have to be in file format, doc, excel are fine. Really just trying to get a baseline.
Old May 17, 2012 | 05:38 PM
Caboboy's Avatar
Caboboy
It sounds like you may be after a "startup" bin or VE table. I think you'd need to do as much on anything you might find as you would on your own bin since it's a mild combo............SD is soooo individual. Good luck!
Old May 17, 2012 | 06:48 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Sd? Not familiar with that term?
I have a basic tune, timing is in the right direction, however would not mind a comparison or closer baseline for the ve.
My tranny points are good, the fueling a little rich though. I can't run ve master on the 96.
Old May 17, 2012 | 06:56 PM
Caboboy's Avatar
Caboboy
I'm sorry, it's Speed Density. Asking for VE table info indicates you have a speed density car as opposed to a MAF car.
Old May 17, 2012 | 07:16 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Haha should have cout that one. The car is Mass air flow.
Old May 18, 2012 | 10:26 AM
Caboboy's Avatar
Caboboy
It would probably be good to contact PCM for less or one of the other tuners.
To VE Baseline - Help needed
