92 Coolant Sensors
Old May 20, 2012 | 03:15 PM
allbowties's Avatar
allbowties
Default 92 Coolant Sensors
Are there one or two coolant sensors on a 92 LT1? I am only finding one in the book, but I was told there are two. Any help would be greatly appreciated.
Old May 20, 2012 | 04:43 PM
C4fan's Avatar
C4fan
St. Jude '10
On the 93 there are 2 units. I'll have to get my book to see how they are listed but when I found them at the parts store one was listed as a temp 'switch' (located on the front of the water pump) and the other was listed as a temp 'sensor' (located on the pass side head between 6 and 8 cyl). I assume the 92 is the same but not sure.
Old May 20, 2012 | 11:24 PM
dlind4's Avatar
dlind4
The temp sensor is for your temp gage and the switch tells your fans when to engage. Do you have a problem with the temp gage or is the car overheating?
Old May 21, 2012 | 12:02 AM
rodj's Avatar
rodj
The one in the water pump ; the CTS ( coolant temp sensor ) is the engine temp indicator for the computer
and everything it operates (computer turns your fans on )
Old May 21, 2012 | 01:25 PM
allbowties's Avatar
allbowties
Thanks for the feedback.
To 92 Coolant Sensors
