I have a 91' 6sp that I bought headers+ exhaust for, and I want to know what brand bolts and gaskets are the best quality. I've got Stainless works 1 5/8 ceramic coated headers, random tech cat and Corsa catback.
If you ordered Stainless Works, then you will be getting bolts and a special exhaust grade silicone RTV to seal it all up.
Apply about a 1/4 inch bead all the way around each port and let it tack up for about 15-20 minutes. Once it has a little bit of a "skin" on it, go ahead and push everything together. As long as you take your time, it is not messy and it seals perfectly every time with no blow outs.
