Lowering front A-arm spring pockets
Old May 21, 2012 | 06:35 PM
C4vettrn's Avatar
C4vettrn
Default Lowering front A-arm spring pockets
I have only ever scene one C4 done this way. Why arn't more guys lowering there fronts this way? It does require some fabrication and quality welding but it would seem like you wouldn't have any of the geometry issues. I guess it would be similar in concept as a lowered spindle? I am considering this but wanted to see if anyone has had any experience with this and any feedback would be great.
Old May 21, 2012 | 06:40 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Does this means you are going to cut and extend the shock tower?
Old May 21, 2012 | 07:19 PM
dukeallen's Avatar
dukeallen
Old May 21, 2012 | 07:37 PM
littlesk8cracker's Avatar
littlesk8cracker
no i know what hes talking about. i forget which members car had it done, but they cut the section of the lower a-arm that the spring ends rest on, and rewelded it lowered down so the car sits lower without changing anything about the spring. my guess for why people dont do it is because theres much easier ways to lower these cars. it would require finding someone to do quality welding jobs on aluminum a-arms
Old May 21, 2012 | 08:45 PM
C4vettrn's Avatar
C4vettrn
Yes, that's what I am talking about. I have the means to do this I just want to research the ins/outs first. I personaly like the idea and think it should work good in theory. The obvious issue would be to use correct aluminum and thickness along with good tig welds with reinforcing to be as strong or stronger than it was stock.
One of my questions is does a 1in. drop at the pocket equal a 1in. drop in the ride height?
Old May 21, 2012 | 09:04 PM
USAsOnlyWay's Avatar
USAsOnlyWay
I think height changes at the spring ends is about 1:1, I know changes such as lowering wedges are a ratio dependent on spring rate (there is a thread around here somewhere).
I believe that picture floating around is from a Corvette Challenge race car.
Old May 22, 2012 | 03:37 AM
Crepitus's Avatar
Crepitus
I think Kubs or one of his threads had the pic. One was a Challenge car pic. The spring pocket is between the ball joint and the A arm pivot. If you lower the pocket 1" you should get a little more than 1" lower ride ht. It would be nice to know what alloy we are dealing with, it is apparently weldable because we have seen pics. I was thinking a good plan would be to cut and weld a joint in a upper arm then bend it as well as a unwelded span in a press. Compare performance. The joint I had in mind would be simple, cut the floor if the pocket out, offset then fillet weld. It should get about 1/2 inch.
Old May 22, 2012 | 12:20 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Here is my thread on lowering the car with out welding anything:
http://forums.corvetteforum.com/c4-t...he-ground.html
I made a few changes since then. I can get some new pictures this weekend and update the thread.
I think it is Aardwolf who has the challenge car picture. I thought it was in my thread too but I didn't see it.
Old May 22, 2012 | 01:12 PM
C4vettrn's Avatar
C4vettrn
I like it! Thinking out of the box! I wouldn't be affraid to try this on the track I just don't want to try this on the street. Not sayin it wouldn't work. Are the spring ends and bolts inside the tire diameter? I would worry about hitting them on a pot hole or somthing when under full compression on the streets?
Old May 22, 2012 | 01:26 PM
Kubs's Avatar
Kubs
Yes for a street car it may be a little low. The spring and bolt are almost completely inside the wheel. Ill get more pictures this weekend.
To Lowering front A-arm spring pockets
