U-Joints
Old May 22, 2012 | 12:11 PM
cqlink's Avatar
cqlink
Default U-Joints
My '92 Vert needs U-Joints.
I can't recall from last time I was under the car. Do I need four U-Joints (2 front, 2 rear) for the half-shafts?
There are at least eight PNs on AutoParts Warehouse. Does anyone have the AC Delco PNs for my car?
thx
Old May 22, 2012 | 07:35 PM
cqlink's Avatar
cqlink
If anyone knows how many I need and if there is any difference between front and rear, I can try to figure out what I need to order based on website description.
thx
Old May 22, 2012 | 07:37 PM
trackbird's Avatar
trackbird
thx
Each half shaft has 2 joints and the driveshaft has 2 (if you're doing it too). Total of 6. For my '91 I have 4 of one part number and two of another. I bought borg warner heavy duty U-joints so I don't have the Delco numbers handy. Sorry.
Old May 22, 2012 | 07:45 PM
cqlink's Avatar
cqlink
Can you shoot me the Borg Warner PNs with designation (half shaft and driveshaft)?
I'll see if I can find them online.
Old May 22, 2012 | 08:11 PM
Jagdpanzer's Avatar
Jagdpanzer
Denny's Driveshaft has the best C4 Corvette
U-joint rebuild kit you'll find anywhere
http://www.dennysdriveshaft.com/p423...ebuild_ki.html
Old May 22, 2012 | 08:55 PM
TA's Avatar
TA
Get this and be done with it.
Old May 22, 2012 | 08:57 PM
pletzvet's Avatar
pletzvet
Something else to consider before you step up to the parts counter or place your on-line order...do you want permanently sealed U-joints or the greaseable ones and if greaseable, do you want the zerk fitting at the end of one of the cups or in the centre of the u-joint coming out at an angle? Greaseable can be a bit messy over time, but it's nice to know that there is grease in there. The zerk fitting in the centre of the u-joint can be a pain to get to whereas the zerk fitting on the end of one cap is very convenient. Some will caution that any u-joint that has been drilled to accommodate a grease fitting is weakened...depends how much hp you are putting into it. Spicer brand seem to be a solid choice.
Old May 22, 2012 | 09:40 PM
rodj's Avatar
rodj
Half shaft are Spicer 1350 series
http://www.actionmachineinc.com/5-178xu-joint.aspx
http://www.actionmachineinc.com/5-1350Xu-joint.aspx
Driveshaft are Spicer 1310
http://www.actionmachineinc.com/5-153xu-joint.aspx
Available anywhere especially truck / driveline shops
To U-Joints
