Torque Specification
Old May 22, 2012 | 07:00 PM
starfire54's Avatar
starfire54
Default Torque Specification
I have 96 LT4 that needs to have the valve cover gaskets replaced, however I do not know the torque spec?
Old May 22, 2012 | 08:27 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Just the valve cover gaskets?
IIRC the gasket set also cones with gaskets for each bolt.
Good and tight should work, it does on my 92 that only has the perimeter gasket.
Old May 22, 2012 | 09:00 PM
MissileDoc's Avatar
MissileDoc
Tighten the valve rocker arm cover studs to 12 N.m (106 lb in).
Old May 22, 2012 | 09:02 PM
pletzvet's Avatar
pletzvet
I'm sure there is a torque specification, and can look it up if necessary, but I would caution about putting very much weight into them. Aside from the risk of snapping a stud, the valve covers do not need to be tightened down hard, otherwise you'll simply overcompress the gasket (cork or rubber) and squeeze it out and then you'll be back to metal on metal. A gentle amount of torque is sufficient and then tighten them down a little more (evenly!) after you have put a few miles on the car.
Old May 23, 2012 | 07:28 AM
WW7's Avatar
WW7
I am very careful when torquing into aluminum and on most aluminum parts I just tighten it by feel....I have stripped a few threads out by using a torque wrench.I believe this is because the bolts have been removed so many times the threads are partially worn... On runners and the plenum I just go until the bolt stops, then go a little bit more...The one exception is the intake manifold, these seem to be able to handle the torque without stripping..
On the valve cover bolts I would just go until you make contact with the gasket, then compress the gasket slightly. If you get a small leak you can always go a bit more.....WW
Old May 23, 2012 | 10:05 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
OK, There are a couple of bolts on the engine that also call for 106 in/lb torque. I can tell you that you have to be real careful getting to that torque. - It ain't much past what I call snug.
I'd go with good and tight and sneak up on it to avoid stripping the threads. You can tell when the gaskets are compressed.
Old May 23, 2012 | 10:26 AM
pmihaltian's Avatar
pmihaltian
Slingshot
The rocker arm covers on an L98 engine (84-91) are torqued at 50 lb. in. That's about 4 foot pounds. AND, the L98 valve covers are magnesium while yours are plastic (composit).
Soooooo, the answer is "NOT VERY TIGHT" As said above, just snug.
Just make sure that every couple of months or so you re-torque them, otherwise they start leaking oil. Too tight and you will snap the bolts off or bend, crack or break your covers.
Old May 23, 2012 | 10:43 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It's 106 inch-lbs, but using a 1/4" rachet just "finger tip tight" if you don't have a inch-lbs t-wrench.
Old May 23, 2012 | 04:15 PM
FNLGOT1's Avatar
FNLGOT1
Also, be aware that the FSM has an error on that page. Toward the bottom, it reads ft lbs instead in lbs!
Old May 23, 2012 | 06:42 PM
starfire54's Avatar
starfire54
That is why I asked, the FSM was obviously wrong and I wanted opinions due to the fact I have a leak in that area and felt it would be easy to try the gasket first.
Old May 23, 2012 | 07:50 PM
pmihaltian's Avatar
pmihaltian
Slingshot
YUK !
To Torque Specification
