Rough Idle Fixed
Old May 24, 2012 | 09:22 AM
rezdawg's Avatar
rezdawg
Default Rough Idle Fixed
Havent posted much at all here, but I have been reading every day and have learned a ton about my vette. I owned my own mechanic's shop back in the 80's so I'm no novice, but I was way behind on technology. I have been chasing a rough idle, hunting surging issue for months. After running scans, checking every gasket on the car for vacuum leaks, replacing all the hoses and IAC I finally ordered a set of boschIII's from Jon at FIC. Got every thing buttoned up last night and wow what a difference. Car runs absolutley like new. Just want to send out a big thank you to FIC for a great product and service. Now then to get around to fixing the rest of the stuff that the PO has screwed up on this car.... I found one vacuum hose plugged off with a fence staple!!
Old May 24, 2012 | 10:08 AM
pcolt94's Avatar
pcolt94
A pretty common story on those year cars having bad injectors and the improvement with the new replacement injectors. Sounds like such a simple fix to drive you so nuts.
If you have not done it yet, change the fuel filter.
Old May 24, 2012 | 01:15 PM
rezdawg's Avatar
rezdawg
I changed the fuel filter as soon as I got the car. Like to go ahead and replace all the little things that can leave you stranded quickly. I have learned the hard some way people dont perfom maintenance as often as they should.
To Rough Idle Fixed
