1986 C4 Corvette Issues (Cold idle)
I have done the following:
- Checked ECT using scan tool-> OK
- Checked TPS using scan tool-> OK
- Checked MAF response using scan tool-> OK
- Watched O2 voltage transient using scan tool
- Replaced IAC
- Performed idle reset using the factory procedure
- Checked throttle body (looked clean)
- Checked spark plug and compression on a couple cylinders that were easily accessible (not all)
- Checked injector ohms -> OK
- Checked fuel pressure while idling poorly -> OK
- Applied vacuum to EGR and observed the diaphragm moving ok
- Sprayed quick start over intake, no change in idle speed
- Disconnected MAF (this raised the idle a bit but the stumbling, hesitation and hunting is still there, just a little bit better)
Ive done my homework and read through Corvette forum at people's solutions to similar symptoms, but haven't found the solution to this particular problem.
No check engine light.
Here's a video the engine warm, running in closed loop. I will upload a vid of it during cold start tomorrow. http://www.youtube.com/watch?v=fwQC6...ature=youtu.be
Last edited by vector006; Jun 4, 2012 at 08:21 AM. Reason: added more diagnostic proceedures
During a cold start, the engine fires right up, but quickly drops to a very unstable idle and will frequently stall. If it ends up idling steady and you crack the throttle it will stumble and nearly stall until the engine warms up.
Is it just me or do these engines warm up pretty fast? The fans seem to kick on after a short period of time.
I am suspecting bad injectors or a vacuum leak that I cant seem to find using conventional methods.
The ECM starts off in "fast idle" mode of about 1200 RPM and slowly lowers the idle speed to the 600-700 RPM area as the coolant temperature goes up. If the ECM thinks the coolant temperature is already hot it will lower the idle speed much faster (which sounds like your symptoms).
The ECM resets the IAC every time you shut off and start the car. It's self-adjusting.
Idle drops to about 800 rpm, fluctuates up to 1200rpm periodically.
Will stall at colder ambient temperatures.
Throttle response is very poor, it falls on it's face momentarily when you crack the throttle. It actually backfired on me in this video at 0:25sec (my phone's audio microphone isnt very good, sounds like popcorn)
Once it warms up there is no throttle response issues.
Cold start with MAF disconnected: http://www.youtube.com/watch?v=Soc1colOjAs
RPM is high (above 1000RPM), engine RPM still fluctuates up to 1200rpm.
Throttle response is decent
I checked the MAF reading using my scan tool and the numbers look ok to me, and transient air flow readings look good. Im starting to suspect there might be a manifold leak that throws off the MAF reading in open loop operation. Once it goes closed loop it adjust AFR with O2 sensor. But if this were the case, i would expect a check engine light.
Here is a better video showing the idle hunting during warm-up: http://www.youtube.com/watch?v=24b_6_yjq-I
However, when i disconnected the ECT to check base timing, the hunting went away completely. hmm
The timing seems to be an issue that needs to be resolved.
You might benefit from a minimum idle adjustment:
http://www.batee.com/corvette/dcrg/r...scuss_sim5.htm
I already performed a minimum idle adjustment, I was able to get the minimum idle set when the engine warmed up a little. Not sure if that excludes a vacuum leak.
Lilred87:
Thanks for the tip n the EGR, i think im going to have to pull the entire plenum apart looking for clues.
I had a similar problem and with the engine at idle started torqing the runners and plenum bolts.
Problem solved.
