High idle cause
He's thinking it the CPU now.
I read somewhere that the CPU could be getting a signal that the engine is cold and therefore send more fuel to the injectors, which when I look in there, it does appear to be sending a lot fuel for just sitting there at idle.
My engine water temp is not hooked up to the dash at the moment. The wire needs to be replace and in the meantime we have installed an external water temp gauge.
Being that the dash water temp is not hooked up, is this the same signal that should go to the CPU and tell the engine to stop racing? Or is this controlled by a different sensor?
Not sure what year you have, but on the LT1, the ECM uses the ECT sensor on the water pump. The other sensor is just for the gauge. If your TB or other source is letting too much air in, the ECM will know that and add in more fuel. The car will run rich in warm up until it goes to closed loop operation, but just dumping more fuel in wont cause a high idle without more air, it actually tends to lower the idle I think if it is just adding too much fuel.
So assuming that you have no vacuum leaks and your IAC/ECM is working right I would look at the throttle plates and see if they are stuck open or try to push on the top of the throttle plates as if you are trying to close them. If that changes things, I would suspect that someone has messed with that screw, especially if your car is not stock and certainly if the little tamper proof cap that is supposed to prevent you from messing with that set screw is missing. That is the problem with 20+ yr old sports cars, hard to find one that someone hasnt messed with at some point.
What year is your car? Makes a LOT of difference. I would guess 84 based on your sig, but please verify that.
The ECM uses the coolant temperature sensor on the front of the intake manifold. Completely separate from the dash temperature sensor.
