Compessed air and water rad flush
Old May 25, 2012 | 02:05 PM
J W Drew's Avatar
J W Drew
Default Compessed air and water rad flush
I am going to have my mechanic remove and clean my radiator on my 85. He has a tool that combines water and compessed air that he suggests he use to flush the engine. Anybody ever heard of this procedure? I'm worried about potential damage.
Thanks, JW
Old May 25, 2012 | 02:19 PM
caddyboy84's Avatar
caddyboy84
Thanks, JW
I just did all of this on my car Sunday and it's not that hard. I drained my rad and re-filled with water and ran to temp to open the stat. I re-did this till I was clean. I refilled the rad with very hot water from my slop sink (I turned-up the water-heater stat on the tank). Then I removed everything and pressure-washed the rad, the condenser, the cavity and added a tranny cooler. I also removed the overflow and washed that out as well. It all took a couple of hours, better than paying someone and risk it not being done the way I'd like it to be .
Old May 25, 2012 | 02:50 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The OP is talking about a tool specifically designed to flush the system using water, and "shop air".
It works very well, and won't damage anything that was serviceable in the first place. Caddyboy84's method works too, just takes way longer.
Old May 25, 2012 | 02:53 PM
caddyboy84's Avatar
caddyboy84
Gotta pic of this tool?
Old May 25, 2012 | 03:02 PM
J W Drew's Avatar
J W Drew
Will get a pic and description next week.
JW
Old May 25, 2012 | 03:04 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yep. You can have a look right HERE
Old May 25, 2012 | 03:14 PM
caddyboy84's Avatar
caddyboy84
NICE!! I'm gonna get one. That would've given me more beer time Sunday, my way IS a little time consuming I'm assuming you need to regulate the pressure to under 19psi, you wouldn't want it to be a pressure tester as well.
Old May 25, 2012 | 03:17 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
YEah, it's a sweet tool, and yes, you want regulated air. They are spendy though. I have one for my shop, but I probably wouldn't buy one for myself/home just b/c of the price. IIRC, it's ~$500.00 for the kit w/a fancy carry case.
Old May 25, 2012 | 03:20 PM
caddyboy84's Avatar
caddyboy84
NOOOooooooo........Back to the drawing board. I'll look hard at that picture and make one. It looks like $20 in parts. I'll modify my extra sand-blaster gun handle..
Old May 25, 2012 | 03:43 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ha ha....I hear you!
Old May 25, 2012 | 04:40 PM
J W Drew's Avatar
J W Drew
How about damage to the heater core?
Old May 25, 2012 | 06:55 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Again, if the thing is serviceable, it won't be an issue. If the thing was going to spring a leak tomorrow anyway...well then it just might start leaking "today" with the flush instead. Wouldn't stop me from using it though.
Old May 26, 2012 | 03:34 AM
powerpigz-51's Avatar
powerpigz-51
I have one, and it was about 15 bucks at Harbor Freight. I have unclogged many a radiator and heater core. You could easily make one with a schrader valve and a hose nozzle. I use a bike innertube and zippy ties for rad connection, and a heater hose for cores. Reverse flush them. I have a feeling that a few overheating Vettes would benefit from a good reverse flush. I look for cold spots on radiators with a IR temp gun. Beats changing out a heater core any day.
Old May 26, 2012 | 04:27 PM
Crepitus's Avatar
Crepitus
powerpigz, do you know what harbor freight calls the flush gun? I am haveing a hard time finding it.
To Compessed air and water rad flush
