1992 Stock Audio problem
I recently did a check of all the speakers and the back left is very low and some times pops in and out.
The front two are very low. But when I'm driving all I can hear is from the back right.
My initial thought was that it maybe the speakers and was going to replace them all this morning. Before I did that I did some research and from what I have gathered, the speakers are usually the last to go.
Any thoughts or suggestions?
Will it be a pain in the *** to fix my self or do I need to bring it to an car audio center??
Most likely the problem is in the amplifiers. You can send them to Dr. Dons for repair, with or without the other components. He can install an upgraded CD player in the stock head if you have the original.
My suggestion is to go to the audio shop and have a new radio with new speakers installed. It will be better in every way.
Do a search on the Bose radio and look in the audio section of the forum.
Of course I am assuming you have tried adjusting the balance and fade controls on the radio.
