Need Help Reading Codes 94 Corvette
1. C12
4. H36
9. H62
A.
1.0
Thanks for your help!
http://forums.corvetteforum.com/1576116036-post35.html
C12 is Current problem and 12 is no distributor reference pulses. That just means that the engine is not running and is used as a marker.
The H codes are History, which means that they've been there for a while. It's also possible that they were random problems that are now gone. The only way to know for sure is to do an ECM reset to erase all the codes and see if they come back after you drive the car.
You also have Module 1 (CCM ) and Module 9 (EBCM ) codes
http://tech.corvettecentral.com/2011...trouble-codes/
http://www.corvette-guru.com/uploads...CMCodePull.pdf
