Prothane total kit not total?
Old May 27, 2012 | 12:53 AM
The Plastic Lizard's Avatar
The Plastic Lizard
Default Prothane total kit not total?
I got the red poly bushings in the total kit for my C4.
Started inthe rear suspension and found that the long bolt connecting the spring to the rear knuckle had four bushings. But in the replacement kit their are only 2.
Am I supposed to have two poly and two rubber bushings?
What's up?
Old May 27, 2012 | 01:21 AM
vetteoz's Avatar
vetteoz
Originally Posted by The Plastic Lizard
in the replacement kit their are only 2. What's up?
One above / one below
Old May 27, 2012 | 03:03 AM
oldalaskaman's Avatar
oldalaskaman
ask em for the rest of yer parts?
Old May 27, 2012 | 10:21 AM
The Plastic Lizard
Now I am confused, my vette had 4 bushings and the picture of vetteoz only has 2.
How about the rest of you. Two or four?
Old May 27, 2012 | 02:03 PM
littlesk8cracker's Avatar
littlesk8cracker
theres 4, one on top and bottom of each side
Old May 28, 2012 | 12:32 AM
Cliff Harris's Avatar
Cliff Harris
What year?
My '86 has two.
Old May 28, 2012 | 10:09 AM
The Plastic Lizard
It's an 84 and had 4.
Old May 29, 2012 | 02:30 AM
vetteoz's Avatar
vetteoz
Now I am confused, my vette had 4 bushings and the picture of vetteoz only has 2. ?
Your initial statement said
" the long bolt connecting the spring to the rear knuckle had four bushings".
So to clarify; four bushes on the one bolt or 4 on the car total????
Pic above is of one side ; multiply it by TWO to get total bushes required
Old May 29, 2012 | 11:28 PM
The Plastic Lizard
Well I may be slow, but I can count to 4. My 84 has 8 bushings, 4 on each side. The prothane kit has 4 total. It is listed as an 84 kit.
Anyway 2 of the bushings were decent, so I put the poly bushings on top and bottom and the two decent bushings in the middle. Either way it was a giant pain in the butt. All went well except the large bushings that go on the Dana suspension. It required a long pipe, a torch, a dremal, and an ice pick.
Old May 30, 2012 | 03:21 AM
vetteoz's Avatar
vetteoz
Obviously the 2 bushes in the center are for looks as they will never serve any purpose by coming into contact with anything
Old May 31, 2012 | 12:29 PM
PROTHANEtech's Avatar
PROTHANEtech
1st Gear
@The Plastic Lizard,
I believe the bushings in question here are the rear spring cushion bushings (Kit #7-1020) included in our 84-96 CORVETTE TOTAL KIT# 7-2013.
Kit# 7-1020 CORVETTE REAR SPRING BUSHING KIT includes four (4) bushings and four (4) washers total, so it appears you received the correct number of bushings.
This kit was designed for a broad application range (84-96 Corvette), which is reason the kit only includes 4 bushings. The bushing count discrepancy may be an isolated issue with the 84 model, but we have been selling this kit for many years without any fitment problems.
If you look around at other manufacturers spring cushion kits for the 84-96 corvette, four (4) bushings is the standard.
If you have any more questions feel free to email me keith@prothane.com
Old May 31, 2012 | 11:43 PM
The Plastic Lizard
Thanks for the info. The 84 had 4 bushings per side. So it must be different than the PETA. But only 2 take abuse and the others are just place holders.
So I'm good
To Prothane total kit not total?
