Oil temp
Old May 28, 2012 | 07:34 PM
gunnerjuju's Avatar
gunnerjuju
Default Oil temp
Fixed my o2 sensor & went out for a long ride. Oil temp is now displaying Lo. Going to check connection to sensor. If that's not loose what else should I check?
Old May 28, 2012 | 08:28 PM
WW7's Avatar
WW7
It may be the sensor itself, "Lo" is the default setting for the sensor..When mine went bad it wouldn't read anything but "Lo"..These sensors aren't cheap, I paid $80.00 for mine..If you have a Factory Service Manual it should tell you how to check the wires and switch first to make sure they aren't the problem....WW
Old May 28, 2012 | 09:03 PM
gunnerjuju's Avatar
gunnerjuju
you ain't kidding about the price. ranging from $53 to $100. Auto zone has a oil temp switch listed @ $19.00. Is there realy a difference?
Old May 28, 2012 | 09:06 PM
gunnerjuju's Avatar
gunnerjuju
I shouldn't have any driving it while with the sensor inoperable should I?
Old May 28, 2012 | 09:13 PM
WW7's Avatar
WW7
If it $19.00 its not the oil temp sensor, I've never seen one that cheap. It's a sensor, not a switch..I drove mine for a few months without any known oil temperture showing , but its better to have one thats working. Most normal cars don't have an oil temp gauge, just an oil pressure gauge...WW
Old May 29, 2012 | 01:01 AM
Cliff Harris's Avatar
Cliff Harris
Unplug the connector from the oil temperature sensor and ground the connector. You should see a very high temperature on the dash. This will tell you if the wiring and dash are good.
Old May 29, 2012 | 10:04 PM
gunnerjuju's Avatar
gunnerjuju
cliff, thanks for the advice. I'll try it out this weekend and update. I love our cars
Old May 31, 2012 | 09:55 PM
gunnerjuju's Avatar
gunnerjuju
Cliff, I tried to ground the wire but it still read LO so I just cleaned it and replugged it and all worked well. I don't understand what I did wrong because I'm sure your advice on how to test is correct. I'm just glad it's working again. I feel like Im $100 richer. Thank you for the assist.
Old May 31, 2012 | 10:33 PM
383vett's Avatar
383vett
Glad you got it working. Most cars don't have an oil temp sensor. Unless you are into road racing, it's really not that important. I use it at the drags to make sure my oil temp is at 150 before I make a pass. Now an oil pressure gauge is a different matter.
Old Jun 7, 2012 | 08:46 PM
C4in mesa's Avatar
C4in mesa
I just changed my Castrol regular motor oil to Mobil 1 10W-30 synthetic. I also put a K&N oil filter on. Now I noticed my oil temps are as high 260+ degree's. Normal driving never raised my temp to over 260 degree's. Any thoughts ? My L-98 has over 193,000 miles on it and still runs strong. I can reach 140mph no problem (3500 rpm) and faster if I wanted to push it. All stock except for K&N air filter, smooth air coupler and a upgraded air foil. Other than that 2 Dynomax mufflers. I usually drive around 70-80 mph on the freeway. I dont want to kill that old engine with high oil temps. I have had the car less than a year and it is my first Corvette. Sadly I always drove Nissan Z sports cars. Never again.
Old Jun 7, 2012 | 11:03 PM
gunnerjuju's Avatar
gunnerjuju
I loved the 280 ZX's that being said my oil temp has never gotten that high unless you count the time I over heated and blew a head gasket. But then again I've never been able to get mine to go 140 mph
Old Jun 8, 2012 | 02:55 AM
Cliff Harris
My oil temps are usually within about 10 degrees or so of my coolant temps. I do have the Z51 option which has the oil cooler, so that might be a factor.
Old Jun 8, 2012 | 07:01 AM
WW7's Avatar
WW7
Even without an oil cooler mine never gets higher then 18-20 degrees higher then the coolant temp...WW
Old Jun 9, 2012 | 10:49 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86 with a Dewitts stayed in the 25-28 higher than water.
Recently I installed the OEM water/oil exchanger.
Now the oil is about 20 higher.
BTW This on a two hour journey at 60mph with 90 OAT
Old Jun 9, 2012 | 11:00 AM
C4in mesa's Avatar
C4in mesa
My oil temp never went over 255 degree's even when I was driving over 100mph. Recently I changed my regular Castrol motor oil to synthetic Mobil 1 10W-30. Since doing that my oil temps have been higher than ever before. My coolant tends to run 200-220. At night my coolant stays 190 degrees on the freeway. I was told maybe go with a thicker synthetic oil. I am tempted to install a oil cooler. I have over 193,000 miles on this engine. I hate to trash it with high temps. Am I over reacting ? Stock L-98
Old Jun 9, 2012 | 12:00 PM
ddahlgren's Avatar
ddahlgren
In AZ I would be running 20-50 it's never going to get cold enough to need thinner than 20. With all those miles you have gained a bunch of bearing clearance compared to when new. I also would not consider the factory gauges race grade and certainly no lab grade. Comparative to what is normally seen a better guideline. Your old worn out oil pump is at capacity now just feeding the engine I suspect the load of an oil cooler would cut pressure to the bearings and that will be the END...
Old Jun 10, 2012 | 08:37 AM
WW7's Avatar
WW7
In other words what he's saying is " If it ain't broke , don't fix it".......WW
To Oil temp
