94 leaking fuel
Is this a new problem, or has it been leaking for a while now.
Could be a problem with the fuel rails.
if you say its leaking from INSIDE the exhaust pipe and manifold, then you have a blown fuel regulator thats flooding the engine with raw gas and has probably filled the crank case with gas. Pull the dipstick and see if you have TOO MUCH oil on the stick...
A shorted fuel injector will do this also.
That is the only way that raw gas can fill the engine and leak out the manifold.
IF its leaking from above and dripping down onto the pipe...follow the leak and see where its coming from.
BUT
DO NOT try to start that car until you KNOW where the gas is coming from, and that it has stopped. You WILL burn your house down..car too.
The fumes can ignite from the heat of the cat or any stray spark. IF the engine is flooded with gas it could be much much worse...like an explosion if a spark found the gas in the pan...
I've seen some scarey **** before, but the thing that had me shaking for a week was a C4 that was filled with gas from a shorted injector and I tried to start it not knowing any better....and it blew raw gas all the way thru the exhaust when it fired and ran on one bank for about 10 seconds and OUT the tail pipes....lots of raw gas blowing out the back of the car... Thru a hot cat and the crankcase was full of gas also. The car was parked inside the garage too.
That is something that scared me half to death and something that I got very lucky with..nothing ignited or burned.
Find the source or at least narrow it down to something internal or a leak on the outside from an injector or a line thats dripping down onto the pipes. It shouldn't be too tough. Just use common sense and do ventilate the garage or the space and use caution as long as there is liquid and fumes present.
Fuel injection has a LOT of places for gas to leak. Each inj has several O-rings, every section of the fuel rails have a handful of O-rings, fuel lines, regulator...return lines...lots of places. You just got to get in there and look.
on the left fuel rail, rear, is a fuel pressure regulator. Remove the vacuum hose and inspect it for signs of fuel.
If you tighten the fuel cap back down the fuel leak may return.
x2
