The PKE module
Old Jun 1, 2012 | 11:34 PM
Silent Thunder's Avatar
Silent Thunder
Default The PKE module
I've been told that the PKE module is high up on the dash behind the DIC display. Is this something I can gain access to by looking behind the dash from the floor or is it a bear and something the dealer should swap?
Old Jun 2, 2012 | 09:07 AM
markKlein's Avatar
markKlein
I've never done it, but I am told it is a bear. I don't believe you can get to it without removing the dash.
Old Jun 2, 2012 | 11:16 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Here's a thread with pictures.
http://forums.corvetteforum.com/c4-g...tallation.html
A person did post not long ago about replacing the PKE module
by removing the DIC and cutting a hole and reaching in
to remove the PKE module.
Removing the dash cover does take some time but it can be done with some patience.
Old Jun 6, 2012 | 10:25 AM
pcolt94's Avatar
pcolt94
The only comment I can add to getting the PKE out is to remove the 2 screws holding the center A/C vent to the dash. It gives you a little more room and flex to get the PKE box out of the tight fit.
I personally would not cut any holes. Not really needed especially if you are going to do all that work, why take a non-productive short cut. Not even sure if it would save and time or effort.
Old Jun 27, 2012 | 08:43 PM
Silent Thunder
Put the new PKE module in and the FOB's work! Yea.
Old Jun 28, 2012 | 07:23 AM
bac22's Avatar
bac22
Removing the dash is actually a piece of cake...at least in my 96...probably takes 30 minutes at most...then again I've done it 3 times over the last 5 years do deal with @#$% mice!!!
To The PKE module
