antennae help needed
Old Jun 2, 2012 | 03:50 PM
bvectra's Avatar
bvectra
Default antennae help needed
I have a 93 antenna that I want to put in my 92 wires are different but antenna seems the same need to match up the wire to make work and change plugs too
93 orange, pink, black
92 white , green, black
Old Jun 2, 2012 | 07:39 PM
Hooked on Vettes's Avatar
Hooked on Vettes
The 93 Antenna has a built in relay.
The 92 used an external relay.
If you want to swap the 93 Antenna into a 92 you need to
cut the plug off of the 93 antenna and splice the three wires to the
Antenna relay.
Assuming you have a coupe.
At the Antenna relay located under the center black plastic
hatch cover (where the hatch release solenoid is) is the
relay.
93 antenna Orange wire to the Orange wire at the relay.
93 antenna Green wire to the Pink wire at the relay.
93 Black wire to Black wire at antenna relay.
The relay is now unused so you can remove or leave it
in place.
