Rear spring swap question
Old Jun 4, 2012 | 03:39 PM
vettecooler's Avatar
vettecooler
Default Rear spring swap question
Hi, I am changing the rear spring on my "88" from a base spring to a Z51Optional (NYU) spring from an "89", can any one tell me if the shims are the same size, if not what size shims well I need...........Thanks
Old Jun 4, 2012 | 03:52 PM
383vett's Avatar
383vett
They both should use the same size shims. You'll have to bolt everything up and check the ride height. You may need to swap shims from top to bottom to get it dialed in or use longer bolts on the ends of the spring to give you greater adjustability.
Old May 25, 2013 | 06:05 PM
ZICK's Avatar
ZICK
88? Lol !
Old May 26, 2013 | 04:45 AM
gerardvg's Avatar
gerardvg
Z51 option suspension option also comes with a lower ride height, also you should not mix hard and soft springs. You should install a Z51 front spring also.
GM designed the spring rates front and rear for best handling, best not to mix and match but usually cars are designed with a softer spring in the rear as most of the weight is in the front.
The easiest way to improve handling and control ride height, is to remove the composite springs and fit coil overs.
See the link below.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1972
Old May 26, 2013 | 07:48 PM
93Rubie's Avatar
93Rubie
Each spring base, FX3, or Z51/Z07 had specific spring shim package setups. The combinations found in the FSM. I know b/c when I changed my 93 FE1 base NYR spring to the NYU from a Z07 I looked up the shim combination in the FSM. You get one of those your golden.
To Rear spring swap question
