A.I.R. Pump Eliminator???
Old May 23, 2002 | 09:16 PM
ZAD54's Avatar
ZAD54
Default A.I.R. Pump Eliminator???
Does this really effect performance as much as claimed or does it just lighten my wallet $160. :seeya
Old May 23, 2002 | 09:19 PM
scorp508's Avatar
scorp508
For the most part just lightens your wallet. I have one (bought used) because I like how it cleans up the engine compartment. It also makes it much easier to set the timing as you can see the timing tab much easier.
Old May 23, 2002 | 09:32 PM
Rob90's Avatar
Rob90
Default Re: (scorp508)
I could tell no peformance gains but like scorp said it does make the engine bay much cleaner
Old May 23, 2002 | 09:34 PM
ZAD54's Avatar
ZAD54
So what you're saying is that if I'm getting it purely for performance, then I probably won't be satified with the results. Now if I really wanted to get some power, I'd tear my good ole L98 down like you did and go ***** to the wall. By the way, great job!!!!!! :cheers: :seeya
Old May 23, 2002 | 09:40 PM
Rob90's Avatar
Rob90
Default Re: (ZAD54)
If you can find one used I think it is worth the money to clean up the engine. I though I saw one in the 4-sale section the other day.
Old May 23, 2002 | 10:00 PM
UDLUV12's Avatar
UDLUV12
Default Re: A.I.R. Pump Eliminator??? (ZAD54)
Zad54,
Spend the money, and clean up your engine compartment.
Do it now, before you make the additional modifications you mentioned, and you just might feel a seat of the pants difference.
Once you make the mods, chances are you will not be able to feel it.
I just added this Air Pump Eliminator Modification, about 2 months ago, and I couldn't tell a difference.
However, I have many of the mods to my engine that you wish to do in the future. Like the other members before me...I do like the way it 'cleans up' the compartment.
$160...not a bad price to pay, for what it does.
Old May 23, 2002 | 10:22 PM
chucks88's Avatar
chucks88
Default Re: A.I.R. Pump Eliminator??? (UDLUV12)
I put a kit in my ride in November. I have no dyno or track b4/after results, but every little bit helps. It does give you tons more room especially after removing the air box(smog pump, maybe) thingy. :rolleyes:
I took me about 4 hours to do it. But I work slow.
Old May 23, 2002 | 10:42 PM
johnnyevans's Avatar
johnnyevans
they definitely clean up the engine compartment. I built one for myself and used a 6+ inch shorter belt and it looks better, I think!
Johnny
Old May 23, 2002 | 11:02 PM
Vic'89's Avatar
Vic'89
It is worth about 10 HP.
The engine gets cleaned up nicely.
Vic
Old May 23, 2002 | 11:10 PM
Lexdog's Avatar
Lexdog
Default Re: A.I.R. Pump Eliminator??? (Vic'89)
I live in PA and we have yearly inspections. Will removing the AIR pump mess up anything I need to pass inspection? What does the AIR pump do anyway? :yesnod:
Old May 23, 2002 | 11:26 PM
ZAD54's Avatar
ZAD54
Thanks for the advice UDLUV12, but I'm not sure if I'm going to do all those mods now. For that money and selling my car I could have a nice ZR-1. But you know where that goes, I'd just want to modify that too. Who knows, this tax refund is burning my pocket and if another mustang passes me I might just have to do something. :cheers:
Old May 23, 2002 | 11:44 PM
GRX's Avatar
GRX
It also makes things a wee bit quieter because the air pump does make some noise. It also saves your air pump for when you need it...smog test...resale...
Old May 24, 2002 | 02:19 PM
89vette's Avatar
89vette
Default Re: A.I.R. Pump Eliminator??? (GRX)
I'm thinking of one of these also. Not for performance but for noise. My air pump is really noisy. Its a rebuilt unit I put on last spring. The instructions said that it will be noisy for a while until it breaks in but this is :crazy:
Does anyone have pictures of what the eliminator kit looks like installed?
Jason
[Modified by 89vette, 12:19 PM 5/24/2002]
Old May 24, 2002 | 03:24 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: A.I.R. Pump Eliminator??? (89vette)
Jason
Ask you shall receive
Old May 24, 2002 | 04:00 PM
89vette's Avatar
89vette
Default Re: A.I.R. Pump Eliminator??? (-=Jeff=-)
Hmmmmm. Well I want one of these: http://home.no.net/dwnlod/ferrari-pi...ari/gmp11.html
Sorry, but I dump Vettes for a Ferrari. :D
[Modified by 89vette, 2:01 PM 5/24/2002]
Old May 24, 2002 | 04:34 PM
-=Jeff=-'s Avatar
-=Jeff=-
Would a Matchbox or Hotwheels car be okay? that is all my pocketbook will allow for :D
Old May 25, 2002 | 01:56 PM
jtjerry's Avatar
jtjerry
Has someone diameter or schematic that eliminator?
Paying 160 $ for one simple piece of steel (aluminum) and for one pulley on ball bearing it is simple thefting!!!!
Jerry
To A.I.R. Pump Eliminator???
Old May 25, 2002 | 02:01 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: A.I.R. Pump Eliminator??? (jtjerry)
Anybody have a part # for the pulley needed to make a homemade one?
Old May 25, 2002 | 04:12 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: A.I.R. Pump Eliminator??? (War Machine)
I spent the $160 (actually $156 shipped to my door) and like it. I'd do it again. I actually dynoed mine and got maybe a 2hp gain. The air pump doesnt rquire alot of hp to spin up. It does however remove about 20-25 lbs from the front end of the car as well as clean it up. It makes it easier to access spark plugs, thermostat, bottom of the throttle body, timing marks etc etc. If people will pay $40 or better for the air foil or $70 for a K&N filter then pay the $160 for this unit.
Old May 25, 2002 | 04:53 PM
jtjerry's Avatar
jtjerry
Default Re: A.I.R. Pump Eliminator??? (red90sixspeed)
Is there someone interested with done that easy piece of metal at home?
$160 for that it is nonsense :crazy:
I thinking about use original AIR pump pulley
Jerry
