ABS Reset?
Old Jun 5, 2012 | 11:33 AM
red 90's Avatar
red 90
Default ABS Reset?
Can anyone tell me how to reset the abs, Mine is fine for the first 60 seconds then the light comes on and then the pedal is hard to push to stop... Thanks in advance... red 90
Old Jun 5, 2012 | 11:43 AM
pcolt94's Avatar
pcolt94
I'm not really sure about the 90. There is a reset for 92 and up in module 9.0 but I dint think you have the same ABS system.
All I can offer is to make sure the master is very full up to the line, and you might try disconnecting the battery and see it that does a reset. It might do it for the 90 unlike the 92 and up.
Old Jun 5, 2012 | 11:18 PM
93Rubie's Avatar
93Rubie
http://www.corvetteactioncenter.com/...abs_page2.html
You can pull codes and erase same as a 92. Pretty sure.
Old Jun 6, 2012 | 07:33 AM
bac22's Avatar
bac22
Resetting the light isn't going to fix the problem...lights come on when there is a problem and if you pedal is becoming hard to press then you've got a braking problem somewhere.
To ABS Reset?
