Before You Replace Your Fuel Pump...
Old Jun 6, 2012 | 06:36 PM
Jackie Treehorn's Avatar
Jackie Treehorn
3rd Gear
Default Before You Replace Your Fuel Pump...
Was having a crank/no start situation today and thought I'd share a quick fix.
C4 had been sitting for a few weeks and wouldn't start.
Checked the codes and nothing that would affect the engine running.
Figured it was something mechanical so I checked a plug for spark and present.
Put my ear to the gas tank filler and the fuel pump spin up noise was VERY faint. No gas smell in the tailpipes either.
Figured the pump failed but didn't have a pressure meter to check. In lieu of using a meter I got a rag and released the valve to see the
amount of pressure in the rails. Gas just dribbled into the rag. So I turned the engine over to recharge the line to check it again and it started.
Seems the fuel rails/lines can develop a "vapor lock" even though it's a sealed system.
Never would have thought that have been the solution, but I thought I'd share this with everyone before buying a new pump.
Old Jun 6, 2012 | 06:54 PM
383vett's Avatar
383vett
That's a new one.
Old Jun 6, 2012 | 07:38 PM
leesvet's Avatar
leesvet
I've had to bleed off air in the rails before...
its just like old diesels that when run empty, you had to bleed the air out since they had no way of venting air out and until you did,. the fuel could not advance in the system.
In the C4...since the pump only runs 2 sec to prime, if the engines does NOT fire off then the dist cannot send the required reference signal to the ECM to get more pump run time....then its becomes totally up to the fuel pump oil pressure switch to supply power to the pump...which means more time cranking, and it WILL lite off eventually but you have to crank enough to build oil pressure.. After being parked for several weeks this can be a long long time cranking...
The short cut is to prime key on, vent the air at the rail then crank again and it'll fire. Not unusual after being stored or parked for a while.
Its not so much a vapor lock as it is a liquid void, with no place for trapped air to go so the fuel cannot enter the rails..
Old Jun 6, 2012 | 08:10 PM
pcolt94's Avatar
pcolt94
I've always associated vapor lock with lots of heat. I have left my car lots of times in a garage many times for weeks while I was on a trip with no problem. Could you have a different reaction if the car was outside?
A few weeks is not a long time for a car in good shape to sit. Any number of things could affect starting. I'd sure like to know if there was injector pulses from the ECM. Purging the fuel line and having it start may or may not have been a coincidence. Sometimes things just wake up for no reason.
But I'll just leave it with Jackie's theory.
Old Jun 7, 2012 | 01:59 PM
Jackie Treehorn
3rd Gear
I think your assessment is spot on, but I've run out of gas before and didn't have to do this.
The tank was low when I parked it weeks back, but the reserve light wasn't on.
The car was leaning to the drivers side and may have sucked up some air.
Strange one, but it was definitely the fix.
Also checked the distributor module plug wire and it was full of white corrosion.
Brushed and lubed with dielectric grease and it fires up very sharp compared to before.
Anyway, hope this saves a few peeps some hair follicles.
Particularly on the road.
Old Jun 8, 2012 | 04:44 AM
Cliff Harris's Avatar
Cliff Harris
L98s use a circulating fuel system, so "vapor lock" can't happen. The fuel is pumped up to the fuel rails and then any excess fuel is bypassed by the fuel pressure regulator back to the tank. If you look at the connections on the fuel rails, you'll see that the fuel goes through the rails first before it gets to the fuel pressure regulator.
If you think the fuel rails somehow didn't get pressurized the first time you turned on the ignition (the ECM runs the fuel pump for 2 seconds to pressurize the fuel rails for starting and then shuts off the fuel pump so it won't run continuously if you turn on the ignition but don't start the engine), you can turn off the ignition, wait 10 seconds (for the ECM to go through its shutdown routine (reset IAC and do MAF burnoff)) and then turn the ignition back on.
Old Jun 11, 2012 | 05:12 PM
joe paco's Avatar
joe paco
[QUOTE=leesvet;1581006446]I've had to bleed off air in the rails before...
the way I read my 91 FSM, if the engine is rotating after the 2 secs prime, the dist is sending that reference signal to the ecm and the FP continues to have current, thru FP relay. does not have to wait for the oil pump switch. I think it also says that IF the FP relay is not in the circuit, the fuel rails were not primed for the 2 secs, and the op switch will have a longer crank time, but the oil pressure is only 4 lbs or so to engage the switch. I agree with Cliff that with the fuel return system it should not vapor lock.
Old Jun 11, 2012 | 08:13 PM
383vett's Avatar
383vett
There should be no air in a closed, recirculating system, pressurized or not.
Old Jun 11, 2012 | 08:27 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Coincidence. Not reality. "Vapor lock" which comes from the boiling of fuel doesn't happen on a cold engine.
Furthermore Vapor lock doesn't occur on a recirculating fuel system, such as those used on C4's.
Lastly, Vaprolock doesn't occur on 30+ PSI fuel pressure systems, as those found on C4's.
But even if somehow the fuel rails miraculously became "air locked" it is NOT at all like a diesel as leesvet suggested. Unlike a diesel, it is "self bleeding". Key on, system pumps fuel through the loop and "self bleeds". Any air trapped in the rail (LT1 only) gets "bled" out with the opening of injectors.
Summation of the first post? COINCIDENCE.
Old Jun 11, 2012 | 08:44 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
This is 100% correct. The oil pressure switch is only there as a back up in case the fuel pump relay fails while driving.
Old Jun 11, 2012 | 08:47 PM
VetteMed's Avatar
VetteMed
Originally Posted by Tom400CFI
Coincidence. Not reality. "Vapor lock" which comes form the boiling of fuel doesn't happen on a cold engine.
Lastly...even if somehow the fuel rails became "air locked" it is NOT at all like a diesel as leesvet suggested. Unlike a diesel, it is "self bleeding". Key on, system pumps fuel through the loop and "self bleeds". Any air trapped in the rail (LT1 only) gets "bled" out with the opening of injectors.
That was my suspicion as well. Just didn't make sense in my mind.
To Before You Replace Your Fuel Pump...
