intake manifold gasket Q!
Old Jun 7, 2012 | 09:18 AM
AZ86Vette's Avatar
AZ86Vette
Default intake manifold gasket Q!
Hello all,
So im trying to figure out where and what intake manifold gasket to order... Not having too much luck... I dont need the top gasket set, and thats all ive seen online, autozone, and ect...
Can i just order one from jegs or summitracing for a gen 1 small block? Or does it have to have the rear water channels blocked?
I need some help here haha, Links to products will help me so much!!
Kris
Old Jun 7, 2012 | 09:32 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I have a FelPro performance intake gasket on mine, part number is either 1204 or 1205, not sure which now. The water jacket holes are open on that gasket but the manifold is not so it works fine.
Just checked Summit, part number is 1205 & I got it at O'Reilly's
Old Jun 7, 2012 | 09:55 AM
AZ86Vette's Avatar
AZ86Vette
Thank you for the quick reply!
How did you clog the water jacket holes on the head?
Kris
Edit***
Just re read your post!! Ok so ill check my intake manifold... Mine is the Superram base and top... im at work but ill check when i get home
To intake manifold gasket Q!
