radiator trash
Old Jun 8, 2012 | 09:49 PM
tankman's Avatar
tankman
Originally Posted by caddyboy84
Take a look at "My Garage" pictures so you get an idea of how to do the screen on the air-opening.
Okay,I will,and thank you very much for the help you have provided me.
The '87 is not my daily driver so i can take my time .
Old Jun 9, 2012 | 12:49 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Just a tip on the wire mesh. Home Depot also carries gutter guards which are a tad bigger than the opening of the bottom of your Vette. They are only about a buck apiece and you hardly waste any of it. They also make great gill inserts.
[IMG][/IMG]
Old Jun 9, 2012 | 02:48 AM
Cliff Harris's Avatar
Cliff Harris
Originally Posted by leesvet
The smart move is to get the hacksaw and cut a slot in the shroud ends so that next time it can be lifted off without having to d/c any lines or hoses.
I did this years ago and it really makes it easy to get in there. I've been meaning to do an article on how to do this. Someday...
My hot tip is to seal the bottom of the A/C condenser to the shroud where all the trash sneaks in. I used two lengths of foam rubber with sticky on one side, 3/8" thick by 1/2" wide. Two pieces because of the way the bottom edge of the condenser is shaped. The home improvement stores have rolls of this stuff. The last time I took it apart I found ONE LEAF, nothing else.
Old Jun 9, 2012 | 04:06 AM
caddyboy84's Avatar
caddyboy84
Those grills look nice and that foam-rubber is a great idea, wish I heard about your idea when I had it apart
Old Jun 9, 2012 | 08:23 AM
Midnight 85
Thanks, glad you like them. I wish I had known about the foam rubber thing too, or thought of it myself. I just had mine all apart doing a cam change. My bottom screen has been in place though for about 4 years and when I pulled the rad to do the cam there was very little junk in there. Believe it or not there was a bird carcass in there the first time I did it.
Old Jun 9, 2012 | 08:32 AM
caddyboy84's Avatar
caddyboy84
Yeah, I was reading about your bird experience, that's crazy man I'm thinkin that you had possible diseased air blowin around you, you didn't happen to get sick durring that time did you?
Old Jun 9, 2012 | 09:34 AM
Midnight 85
Nah, he was just a little twerp.
