Misfire
Old May 24, 2002 | 09:29 AM
PL95's Avatar
PL95
Default Misfire
I have noticed a missfire on my 95 Lt1. I changed the plugs and it still persists. Last night we finally had a nice night, so i took it for a ride to see if it continued on a dry day. It was worse. Also, a "SYS" code started to flash where the milage normally is. Today i found plug wire 5 has rubbed through the coating to the wire. Would this be the problem or does the "Sys" mean somthing else? Anyhelp would be appreciated. thanks in advance.
Old May 24, 2002 | 09:47 AM
Kizmo's Avatar
Kizmo
Default Re: Misfire (PL95)
I just replaced my plug wires. My #5 & #7 had cuts all the way through the jacket. At night you could see the sparks fly. I had a slight miss before the replacment and now everything is running smooth.
Sorry, but I don't know anything about the sys code. Your at the right place to find out though.
See ya :seeya Kizmo
[Modified by Kizmo, 1:48 PM 5/24/2002]
Old May 24, 2002 | 11:23 PM
jfb's Avatar
jfb
Insulation missing on a plug wire shows that it is rubbing on something and it should not. Reduce the insulation and this will be a spot where the spark will occur and not at the plug gap causing that cylinder not to fire and the engine to shake at idle and a felt "miss" at driving speed. Dress that wire away from where it is rubbing, or better still , also replace the wire.
Old May 25, 2002 | 03:52 PM
bogus's Avatar
bogus
how many miles??? it could be the optispark...
Old May 25, 2002 | 04:33 PM
Kizmo's Avatar
Kizmo
Default Re: Misfire (bogus)
If you go to all the trouble to replace the wires (and I do mean trouble) then you might as well take a peek inside the optispark. You can tell if you need a new one, if not it's a good idea to replace the rotor.
You have a 95 so a problem with the optispark isn't as likley as with older non vented models.
[Modified by Kizmo, 8:35 PM 5/25/2002]
Old May 28, 2002 | 01:24 PM
PL95's Avatar
PL95
I replaced the wires this weekend, and it got rid of the misfire. The drivers side was a Pain in the butt. The passenger side took 15 minutes. Also, wire # 7 and 5 were worn through. I replaced them and the mis fire continued. It was wires that i thought would be fine that were the problem.
The "SYS" code still flashes (not regularly). Yesterday, i took it for a drive and when i got back in to drive home, it took 3 turns of the key to turn over. I never had that happen. It has always been on the first try. I'm concerned because of the problem starting and the "SYS" code. I guess i'll just have to get it checked on a computer.
Does anyone know how to get to the Coil wire? I can not even see it let alone change it.
Old May 28, 2002 | 04:12 PM
tdock's Avatar
tdock
I would get "SYS" flashing on the mileage display after I had been working on the car for a while and the battery wouldn't start the car and needed to be jumped, eventually I replaced the battery and no more SYS light, even after being disconnected and working on the car.
Old May 28, 2002 | 04:42 PM
ZylaRace's Avatar
ZylaRace
Default Re: Misfire (tdock)
Did you ever try reading the codes?
To Misfire
