:0 help!!!!!!!
Old Jun 13, 2012 | 12:26 PM
85 C4ORCE's Avatar
85 C4ORCE
Default :0 help!!!!!!!
Went out side to drive the vette to work yesterday and when i turned the switch over it fired up beautifully but started making a whining noise, so opened the hood to see where it was coming from then i hear a clacking sound. Seems to be coming from the left side of the motor. The clacking is an on and off thing but the whine is constant. So my first guess was bearings in the smog pump or alternator so i did the old screw driver to the ear trick and they both sounded normal. Any suggestions?
Old Jun 13, 2012 | 01:13 PM
ch@0s's Avatar
ch@0s
Taking the belts off and running it a little while will tell you if its an accessories or the engine itself.
Old Jun 13, 2012 | 04:03 PM
HlhnEast's Avatar
HlhnEast
What he said. While the belt is off, spin all pulleys for feelings of roughness including W/P and tensioner. Check P/S fluid, they make a whine when empty.
Old Jun 13, 2012 | 04:34 PM
85 C4ORCE's Avatar
85 C4ORCE
First thing i did was check the power steering its full ill take the belt off when i get home and try that
Old Jun 13, 2012 | 04:49 PM
johnnyjr2's Avatar
johnnyjr2
is your starter staying engaged
Old Jun 16, 2012 | 10:45 AM
85 C4ORCE's Avatar
85 C4ORCE
ok so i took the belt off and as soon as i did i seen the problem. the alternator pulley had backed away from the fan on the front of the alternator and was jus kinda wobbeling so i figured the nut on the front had just came loose (i thjought kinda strange) so i retightened it and when i spun it i noticed it the pulley was terribly off center so i took it completely off and the center of the pulley has been reamed out to big to fit correctly and they dont sell just pulleys so it looks like ill be buying a new alternator
Old Jun 16, 2012 | 10:54 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Or a local armature shop can replace the bad pull/fan.
To :0 help!!!!!!!
