[semi rant]Alternator bench test......
Old May 24, 2002 | 07:51 PM
mikes84vette's Avatar
mikes84vette
Default [semi rant]Alternator bench test......
.....aint worth sheit! My voltage has been reading 11.6 on startup and climbing to a max of 12.6 under normal driving conditions. If i turned on any acc. the voltage would drop to 11.7. I removed the alt. went to auto zone for a bench test. which their 'bench test' showed the alt to be good.
I have fought with this car for the last two weeks,(in my spare time), trying to find where in the circuit the problem was. Finally after finding nothing, like loose connections or burnt wires, I just decided to replace the alternator, I figured i would start there with replacing parts till i got it fixed.
And GOLLY GEE! guess what, It worked.
I started the car after installation, and the voltage read 14.2. I then turned on some accs and still the same 14.1 @ idle. All was fine under normal driving also.
I just wanted to share this, and make aware not to put a lot of trust in those so called "bench test", like the ones at Autozone and so fourth.
[Modified by mikes84vette, 5:53 PM 5/24/2002]
Old May 24, 2002 | 08:04 PM
Oh My's Avatar
Oh My
Default Re: [semi rant]Alternator bench test...... (mikes84vette)
I work at such a place, though not Auto Zone, remeber that though bench testing is for the most part accurate, it CANNOT simulate true engine bay conditions, such as heat, loose alt. belts, etc. Such conditions can affect a alternators performance. I don't mean to bash, as I understand thats frustrating, and their bench indeed may of been defective, just wanted to present some food for thought.
Old May 24, 2002 | 08:08 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: [semi rant]Alternator bench test...... (Oh My)
I don't generally trust them either, you can only hope to have a counter person that is concerned enough to realize that their test CAN be wrong on occassion. :smash:
Old May 24, 2002 | 08:15 PM
mikes84vette
Does this test place a load on the alternator? Or does it just spin it at so many rpm's and measure voltage output at that piont.
Their test showed a little above 14 volts.
Old May 24, 2002 | 09:31 PM
HighHopes85's Avatar
HighHopes85
It places load on the alternator. AutoZone stores had all their alternator testors upgraded about a year ago...or at least that is when they started. Maybe some of the stores are behind the times.
I usually opt for the on-car test, but for a Vette, that usually requires having the gill panel (the one you take out to replace the battery) removed because of the location of the cables and trying to get the inductive pickup on correctly.
Old May 25, 2002 | 04:21 AM
mikes84vette
then according to what you say the "bench test" is useless. :confused:
Old May 25, 2002 | 04:41 AM
Sharky Guam's Avatar
Sharky Guam
The bench test method does not take in to account the various loads that a car goes through. A voltage regulator sometimes acts differently as the loads increase or decrease. With a slight load it may appear to be putting out sufficient voltage. But as the load increase, it may fail. I would suspect that the voltage regulator in your old alternator is defective. :D
Old May 25, 2002 | 11:26 AM
Oh My's Avatar
Oh My
Default Re: [semi rant]Alternator bench test...... (Sharky Guam)
Exactly what I was stating :cheers:
Old May 25, 2002 | 12:12 PM
BobMachus's Avatar
BobMachus
I have had that same experience twice. Bench test said good, but when the alternator was replaced everything got better. :mad
To [semi rant]Alternator bench test......
