will the stock pump work??
[ as opposed to blowing up and killing me?]
E85 is conductive, gas is a dielectric fluid and not conductive??
But, then the tanks plastic is and seems pretty darned Non-conductive??
Stuff is showing up conveniently in Atlanta, and it seems that we could get away with 11.5:1 compression using this stuff, and likely pass emissions?
400 Hp C4's?? not very hard to do? Real nice it it's re-power time?!!?
TJM
I would not be running it unless I totally converted the system to be able to handle the ethanol content of the fuel. If your running this on a stock motor w/stock ECM programming your fuel trims will probably be maxed out and still running lean. E85 requires a much richer air to fuel ratio about 9.7:1 verus 14.7 for gasoline.
Yes, E85 inherently has a higher octane rating, but you need more fuel and WILL burn more compared to gasoline for the same power. Ethanol has less energy content per unit than gasoline, so you need more. This is maybe a little offset by being able to run higher compression.
That is the plan. it's a Track only car. The carburetor work is $300.00 to get gaskets, jetting and drilling of passages. 30% increases needed according to the experts.
Braided steel fuel lines are good, rated for methanol, so it's pretty doable.
Pumps start at $200.00, but really are methanol parts.
Pressure regulator to take 12 PSI to 6 would run $100.00
Race gas @ 110 octane is $7.75 to $10.00 a gallon. More at the track pumps.
So this pays for itself in a year.
In Atl. we always have summer blend, so the 85% Ethonal is pretty fixed.
Thanks for the input.
TJM
Dont believe the BS stories. Unless you have stock Multec injectors, nothing is going to crumble away and fail. The pump wont catch fire in the tank. The tank liner wont melt away. The ***** wont come and take your children.
Thanks... no substitute for experience.
Pretty much done with this decision.
@Jack, I was thinking of the Multec's when I was writing my last post.
Still I would not risk it without changing out at least the o-rings. A fuel leak back at the tank is one thing with the stock rubber hoses on the metal lines a fuel leak up in the engine compartment is another.
I agree, tank should be fine, and metal lines. Plastics/rubbers are what I would be concerned about. Mostly a safety thing on those.
carb.. track only car. Sealing is still a concern. $300.00 to get it done right .
