PCM Communication Issue - HELP!
This time while updating, the battery in the car became low and the Hypertech froze at 77% completion and a couple minutes later it lost communication after the car battery basically drained.
I recharged the battery and reconnected the Hypertech at which point it said program interrupted and attempt to reconnect to the PCM. It failed to communicate 3 times.
I connected my Autoxray 7000, and it to was unable to communicate.
I noticed that the SYS light is flashing and the Service Engine light is flashing to many times to count per second.
I've checked the fuses for the CCM and PCM and all looks good.
Did I fry the PCM, what did I do, what happened?
Any help would be greatly appriciated.
Thanks.
If this was a Nissan you would be getting a new ECM, they are unrecoverable at that this point. You always connect a battery charger when programming a ECM. Consider this an expensive lesson in ECM reprogramming.
Not sure if yours is recoverable or not, I doubt it is. Start shopping of a new one/repair yours (if possible).
Hopefully, you did not damage any other modules. Good Luck.
As noted ;
with any electronic device if you loose power part way through the re-programming you have neither the old program
or the new one
May have to send PCM out to be re-flashed back to stock
http://www.madtuner.com/index.php?pa...mart&Itemid=26
or get some basic mods done at same time
http://www.lt1swap.com/programming.htm
Also I will be sending out the ECM to hopefully be reflashed.
As noted ;
or the new one
Worst case scenario I end up with an extra ECM that I can send out later for upgrade reprogramming and not have any downtime.
Was able to locate a brand new ECM with factory programming included for $285.
Now,... Does anyone know anyplace besides Hypertech that can reset the programmer?
Those SOB's want $250 to reset and $339 for a new one.
RIDICULOUS!!
Thanks Again guys you
