C4 Rear IRS Weight
Old Jun 20, 2012 | 06:19 PM
Coconut's Avatar
Coconut
Default C4 Rear IRS Weight
What is the weight of a complete 91 Independent Rear Suspension (IRS)?
Dana 36/44 does not matter to me for this question.
I saw a thread that list weights for various components of the C4, but could not find an entire rear suspension weight.
Thanks.
Old Jun 21, 2012 | 04:53 AM
toptechx6's Avatar
toptechx6
Just checked the shipping receipt for one I purchased out of a 90 ZR1, total weight was 285, keep in mind that includes the shipping pallet, hope that helps.
Old Jun 21, 2012 | 06:26 AM
red L98's Avatar
red L98
It's around 250 from Rotor to roter .. I saved weight going to a straight axle .
Old Jun 21, 2012 | 07:42 AM
Calderone's Avatar
Calderone
Nice thread, any of you guys knows the weight difference between a D36 and D44
pumpkin w/batwing only ? thanks !
Old Jun 21, 2012 | 09:13 AM
dizwiz24's Avatar
dizwiz24
how is that possible?
You are telling me that the steel housings, axle tubes, axles themselves, weighed less than a bunch of aluminum components?
Old Jun 21, 2012 | 11:22 AM
red L98's Avatar
red L98
Yup , Mine was also narrowed 10inches , aluminum spool, gun drilled axles, and chromemoly axle tubes ... I was able to lift the thing off the bed of my truck and to my garage floor all by myself .. try doing that with an IRS
Old Jun 21, 2012 | 02:07 PM
Coconut's Avatar
Coconut
Default Straight Axle
I, too, just switched to a straight axle in my C4 '91. I've done this before in a C3 '82.
Thanks.
Old Jun 21, 2012 | 02:13 PM
Coconut's Avatar
Coconut
Default Solid Axle Weight
Here are some specs from a stock Ford 9":
9-inch Rear End Assembly Weight: 194 lbs.
1. Housing: 38 lbs.
2. Axles: Large Journal, 28-spline - 18 Lbs. ea.
3. Brakes: Massive 11-1/32 x 2½" Drum Assemblies - 26 lbs. ea.
4. 3rd Member: Conventional Diff. - 68 lbs.
a. w/Traction-Lok Diff. - 71 lbs.
Now, when you get into the lighter aftermarket stuff and disc brakes, things get lighter;
Hence, a solid axle saves weight over the heavier C4 IRS.
Old Jun 21, 2012 | 03:39 PM
red L98's Avatar
red L98
yessss , I could've saved more weight if i went with a Fab 9 with an aluminum center section like i 1st had planned , I still punch myself in the face for listening to my friend who talked me into a 12 bolt so i can class race the car.. which i never do or ever will , he even gave me the speech of how a 9inch eats up more HP
Old Jun 21, 2012 | 04:34 PM
Coconut's Avatar
Coconut
I like the 9", because the entire case can be removed to work on it.
The solid axle completed my coil-over conversion as well. I'm not a fan of the mono-leaf spring. It has its advantages & disadvantages like all suspension systems.
Anyway, even with the 12-bolt, you are lighter, & have a solid axle.
Old Jun 21, 2012 | 04:44 PM
STEVEN13's Avatar
STEVEN13
Thanks.
Hey,
Any photos?
Thanks,
Steve
Old Jun 21, 2012 | 04:50 PM
Coconut's Avatar
Coconut
All of my photos are kept on backup sources. I have uploaded others' photos via a link online before, but none of mine are online. In other words, I don't believe I can just upload a photo from my computer onto the forum.
Old Jun 21, 2012 | 04:51 PM
LT1inaMGB's Avatar
LT1inaMGB
Here are actual component weights from my D36
Batwing & pumpkin 60 lbs I understand D44 weight 5-7 lbs more
1/2 shaft 2@10 20
Camber rods 7
trailing arms (all 4) 10
Tie rods 5
Upright w/ wheel brg 2@ 18 36
Late caliper 2@ 7 14
Late rotor 2@ 13 26
_____
Total w/o spring, shocks, 178 lbs
sway bar and torque arm
Jim
Old Jun 21, 2012 | 05:00 PM
STEVEN13's Avatar
STEVEN13
No Problem
Old Jun 28, 2012 | 01:37 AM
Coconut's Avatar
Coconut
When the entire IRS is compared to an aftermarket solid axle, the solid definitely weighs less (especially a narrowed one).
Thanks for the numbers.
To C4 Rear IRS Weight
