Dropped Cylinder
Old Jun 22, 2012 | 10:12 AM
relichunter's Avatar
relichunter
2nd Gear
Default Dropped Cylinder
Drive a '84. Stock motor, upgraded exhaust. After driving for a while and shutting down, if I restart while the engine is still hot, it now runs of seven cylinders. This only happens when hot. Trying to figure out what is happening. Is it dirty injectors/injector, bad plug or computer problem? Driving me nuts, need help, thanks.
Old Jun 22, 2012 | 10:19 AM
383vett's Avatar
383vett
Can you isolate the bad cylinder? Use an infrared laser thermometer to figure out which cylinder is dead. Check for spark. If you have spark, then probably have a bad injector.
Old Jun 23, 2012 | 12:45 AM
Cliff Harris's Avatar
Cliff Harris
You can determine if an injector is bad by unplugging them one at a time (engine running). If nothing changes when you unplug an injector, then that injector is not working.
Sometimes injectors fail when they get hot. You can measure the hot resistance of the injectors and see if there is a difference.
Old Jun 23, 2012 | 01:13 AM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Your 84 has a crossfire injection system. There are only 4 injectors, 2 for each bank. How do you know it is is only running on 7 cyl? What trouble-shooting have you done so far? I need a-lot more info before I could even begin to guess what the problem could be.
Old Jun 23, 2012 | 01:34 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Sorry, but a crossfire only has two injectors, each TBI unit feeds the cylinders on the opposite side. If both show an equal spray pattern I doubt the problem is an injector, and would ask the same question about trouble-shooting..
To Dropped Cylinder
