Intake gaskets.
Old May 25, 2002 | 01:35 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Intake gaskets.
What kind should I get and where should I get them. I have 155K miles on the original ones and since I have a severe oil leak and am putting in new injectors I thought I should do this to. About how much do they cost too. Thanks.
Old May 25, 2002 | 10:37 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: Intake gaskets. (85WHITEZ51)
I find it believe nobody knows anyting about intake gaskets for an L-98 on this forum.
Where do I get them and how much is all I m asking.
Old May 25, 2002 | 10:46 PM
LPDesRoche's Avatar
LPDesRoche
You can either go to your local auto parts store or order them from Summit or Jegs. You don't need anything more than the stock ones at this point. Just make sure you get Felpro gaskets and you will be fine. If you want to order them from Summit the felpro part number for your car is 1204.
Old May 26, 2002 | 04:17 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: Intake gaskets. (LPDesRoche)
Thanks LPDesRoche, I really appreciate it. Didn't know if it was a special order part from somewhere or if I could go to NAPA or AutoZone and get them.
Old May 26, 2002 | 04:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I got the FlePro Intake Manifold Gasket Set #MS 93318 from Auto Zone for about $35. It fits '86-'93 350 engines, so you need a different set. I expect your set will have similar contents:
(1) Black RTV, to seal the front & rear rails.
(1) Throttle body gasket
(1) dist. gasket
(1 each) fuel feed & return O-rings
(8) fuel injector O-rings
(1 each) plenum left & right side runner gaskets
(1 each) intake base left & right side runner gaskets
(1 each) intake base left & right head gaskets
Old May 26, 2002 | 05:07 PM
Vic'89's Avatar
Vic'89
Default Re: Intake gaskets. (65Z01)
It's better to get the whole Felpro set like 65Z01 has stated above. It comes with everything you need. My local Pep boys was able to get them.
Vic
To Intake gaskets.
