air conditioner compresser bracket
Old Jun 24, 2012 | 09:59 AM
whendreamsweep's Avatar
whendreamsweep
3rd Gear
Default air conditioner compresser bracket
my 88 corvette air conditioner compressor bracket is cracked and moving around. Where can i find a replacement? I have looked at numerous sites and no one has one for an 88. Would an 87 fit?
Old Jun 24, 2012 | 10:16 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Call vette2vette in Streator IL.
VERY good to EXCELLENT used Corvette parts.
To help you out: http://www.vette2vette.com/
GREAT customer service!
While driving your Vette, please be sure to SAVE the WAVE!
Old Jun 25, 2012 | 05:23 PM
1986coupe's Avatar
1986coupe
The compressor in the 88 changed from the 86-87. As a result the bracket is different. Check the parts for sale/wanted section of the C4 forum ,the various vendors on the forum, or ebay.
Old Jun 25, 2012 | 08:07 PM
WW7's Avatar
WW7
You can also have it welded..Someone that knows how to weld aluminum can fix it so it will never break in that same spot again..WW
Old Jun 25, 2012 | 09:41 PM
Muffin's Avatar
Muffin
Originally Posted by WW7
You can also have it welded..Someone that knows how to weld aluminum can fit it so it will never break in that same spot again..WW
BINGO. Mine cracked must be 10 years ago, had it welded then I filed it smooth then a tad of polishing It is still holding firm, have to look close to find the repair.
Old Jun 25, 2012 | 10:19 PM
rodj's Avatar
rodj
Most commonly crack because one of the many braces the factory installed has been removed and not replaced
Old Jun 26, 2012 | 10:21 AM
c4cruiser's Avatar
c4cruiser
Find a local welding shop that can weld aluminum. As long as the bracket is not completely broken, it should be a fairly easy weld job.
Don't drive the car any more than necessary. Remove the bracket and take it to a welder. Even cast aluminum can bend, so it's important to insure the bracket is aligned properly to the attaching points on the engine when it's welded.
Old Jun 26, 2012 | 04:46 PM
whendreamsweep
3rd Gear
thanks everybody for all the advice!
Old Jun 28, 2012 | 12:52 AM
Ricky 91 vette's Avatar
Ricky 91 vette
Rodg is right, I had the same problem too and it happened because the ( mechanic) who installed the cam and heads in my car had decided that 2 of the 3 supporting brackets that hold the Ac bracket were uneassacery and he never installed them back!!! I got my new ( used ) Ac bracket for $60 shipped from a member in the furom at the parts section
Old Jun 30, 2012 | 03:01 PM
whendreamsweep
3rd Gear
I could use some help here.
I need pictures of the position of the braces on the mounting bracket for the AC Compressor on an 1988 corvette. I understand there is 3?
Old Jun 30, 2012 | 07:43 PM
leesvet's Avatar
leesvet
You NEED a FSM to see where, how and which go to what.
That set of books is worth more than any picture.
Sorry I can only tell you that the most important a/c bracket brace goes to the exhaust manifold stud. I think there may be 3 braces in different accessory points...like alt, a/c and maybe air pump. Thats how mine is..87.
The PS bracket is in aftermarket production. I've had to buy one. For whatever reason the a/c bracket is found salvage only as of now...The a/c MUST have the brace and be careful of how the tensioner plate rest on the water [pump hose...I broke my bracket running the nuts down tight when the bracket was pressed against a hose clamp for the suction hose...(lower hose). duh..
Loosen and tighten these fragile aluminum brackets as if they were glass. Never run down a nut then go to the next...they don;t flex well..
Old Jun 30, 2012 | 09:19 PM
vetteoz's Avatar
vetteoz
Old Jun 30, 2012 | 09:46 PM
leesvet's Avatar
leesvet
That lower bracket from tensioner plate to the old fuel pump mount sure is needed ! I wish mine had that...
Its amazing at how much torque the belt pulls on the accessory assy when the engine is revved...even a tight assy set you can still see things tweaking around a bit.
To air conditioner compresser bracket
