i bought this 96 last week noticed oil temp gauge dont work,got under the car today,,i found the sender with the cap pluged on top of it,but guess what no wires to be found connected to it,,anybody got any ideas???????? i found no wires hanging blowing in the breese anywhere
My car is 10 years older than yours and things changed over the years, but the wire for my oil temperature sender runs in the same loom as the O2 sensor and the ground wires that go to the side of the block above the oil temperature switch. I have heard that those wires go to a stud on the bellhousing in later years, so yours might be different (and of course you have O2 sensor wiring that I don't have, since I only have one, and it's not heated).
my 91 has the orange wire input, red wire out to OP switch, tan wire to gage. saw a photo of a 96 and it was the same. the wires are tight and run off one side to the harness bundle. can't get to it under the car. -can't get to it, period- it is drivers side right behind valve cover. a second oil press sender is nearby, goes to "check gages."
joe
it pays to read with your spectacles and your brain in gear!
at least he knows where oil pressure senders are.
Reason: spell
i crawled under the car for an hour,trust me there is no wires hanging ,someone must have cut them out,,there is a bundle of wires going past the place but they are wraped like factory,,would someone with a lt1 tell me what colors the wires are and how it gets there
